Old 12-01-2013, 09:09 AM
mburch's Avatar
mburch mburch is offline
Default Alternate air cable (horizontal induction)
From the "picture is worth 1000 words" category, here are some shots of how I did my alternate induction air cable (IO-360-M1B, horizontal induction).
Instead of the plans method, I made little steel brackets and attached the cable sleeve to some handy sump bolts:
And instead of just winding the cable around a screw on the door, I made my own little custom aluminum cable anchor thingy on the mill. It pivots on a brass bushing and the cable wire is clamped between a pair of set screws, loctited in place. Same principle as the "B-nut" found elsewhere, just adapted for this particular application.
I had hoped to find a more elegant way to construct the door that would allow it to be both opened and closed with the cable, as some of you clever guys have done, but I decided not to spend any more time on it right now. Maybe on the next airplane.
Full blog entry: http://www.rv7blog.com/2013/11/04/alternate-air-cable/
Matt Burch
RV-7 (last 90%)
Any opinions expressed in this message are my own and not those of my employer.
Old 12-01-2013, 09:57 AM
Dbro172's Avatar
Dbro172 Dbro172 is offline
Nice work! What happens when you try to close it? I've read mixed reports, seems it works for some.
Derek Hoeschen
EAA Tech Counselor
RV-9A #92103 - N803DK
G3X, Superior XO-320, Dual Pmags, Catto 3B
www.mykitlog.com/dbro172/
1974 Bellanca Super Viking - N16AW - Flying
RV-8 #83565 - N184DK - building
1968 Mooney M20C - N6801N - Sold
1956 C-182 - N744W - Sold
Old 12-01-2013, 10:28 AM
Ron RV8's Avatar
Ron RV8 Ron RV8 is offline
For what it's worth, I laminated an aluminum ring into the glass to avoid breakout, and changed the geometry a bit from the plans. The clevis and threaded coupler are from the R/C model industry for large models. Opens and closes every time...
Ron Townson
Okanagan Valley BC, Canada
RV-8 Completed Dec 2013
Membership renewed Nov 22, 2021
Old 12-01-2013, 10:30 AM
mburch's Avatar
It tries to close but the door doesn't go under the tab, so it doesn't actually close securely. To do otherwise requires a more elaborate mechanism than I was prepared to fool with!
Matt Burch
RV-7 (last 90%)
Old 12-01-2013, 10:56 AM
rzbill's Avatar
rzbill rzbill is offline
Here is a link to the first of 3 pages on expercraft documenting my bypass installation.
Air bypass page 1
The main customization was creation of a "stud" for the curled end of the Bowden cable. This allowed me to leave the metal self locking nut loose enough for the loops in the cable end to rotate freely. Works great and the geometry I wound up with closes the hatch every time, tightly.
Bill Pendergrass
ME/AE '82
Old 12-07-2013, 02:42 PM
mburch's Avatar
Okay guys, you challenged to revisit this, and now I have an alternate air door that can be both opened and closed from the cockpit. The solution was a pair of spring washers and a pivot bushing... now the door no longer flops around when open, so it can be easily closed with the cable:
Full blog entry: http://www.rv7blog.com/2013/12/07/al...e-improvement/
Matt Burch
RV-7 (last 90%)
Old 12-07-2013, 03:55 PM
BillL BillL is offline
Way to go Matt!! Thinking about the issue and resolving with an elegant solution!. I shall copy your process, repeatedly.
Well done.
Bill
RV-7
