11-24-2013, 09:06 AM
Stall Horn Washers Question
SO I am trying to assemble the stall horn today and can't find the washers. I finally look at the packing list to find 30 of the large washers in the attached picture and none of the correct washers. The small washers were the supposed to be NAS1149FN432P. So now I have a bunch of washers of unknown size.
I happen to have purchased a bunch of random nuts bolts and washers from the yardstore. I would like to know if the one I am using are a good substitute. They are labeled AN960-4. I also have AN960-4L. I think that the latter are too thin and would take a lot more washers to stall horn assembled.
It worries me a bit when the correct parts are not in the bags.
Ken Stockman
Midland, MI
EAA Chapter 1093 member
FaceBook Page: Ken's RV-14
RV-14a (serial number 140073)
N73XP
Plane at hangar and the wings ON.
11-24-2013, 09:08 AM
here is a picture of the stallhorn with the AN960-4 washers. It looks OK to me.
Ken Stockman
Midland, MI
N73XP
11-24-2013, 09:56 AM
AN960-4L and AN960-4 are the washers called out on the RV-10 stall warning sub assembly which is identical to the RV-14 assembly. I think someone just took the 432 part of the number of the NAS number for the -4. I used the AN960-4 washers on mine.
Thanks Ron
RV-10 SOLD
RV-14 Flying
AirCam flying
11-24-2013, 10:07 AM
Must be a typo...
The NAS number is for a much smaller #4 washer...
http://www.fastenal.com/web/products...Punchout=false
Type:Flat Washer
Bolt Size:#4
Outer Diameter:0.312"
Finish:Cadmium
Inner Diameter:0.125"
Mil-Spec Number:NAS1149FN432P
Thickness:0.032"
Material:Steel
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
11-24-2013, 10:43 AM
I think that they put in the wrong washers. I don't think that it is a typo. If it was a typo, then I would have been able to find the washers somewhere.
Luckily, I got them about a month ago when I bought a bunch of stuff from the yardstore.
Ken Stockman
Midland, MI
N73XP
11-24-2013, 01:42 PM
Well, something is a typo, because that MS number is not AN4 hardware as the bag calls for...
It does not replace an AN960-416L as the typed description says.
Gil Alexander
11-24-2013, 02:00 PM
I would say the plans are in error here and whom ever made the list used the plans to as a reference. The bag has what the RV-14 plans call for, but that is not what the RV-10 plans call for. The washers called out for the RV-10 application make more sense and that is what I used. I have been wrong once before!!
Thanks Ron
RV-10 SOLD
RV-14 Flying
AirCam flying
11-24-2013, 02:08 PM
I think you are looking in the wrong bag.
The portion of the list you posted (AN4 hardware) is 1/4" inch sized fasteners. An AN960-4 16 Washer has a 1/4 " hole. An AN960-4 has a hole sized for a #4 screw. Leaving a couple of digits of a part # can make it and entirely different part.
I admit it can get confusing with the conversion from AN to MS part #'s, but it is what it is.
Scott McDaniels
Hubbard, Oregon
11-24-2013, 02:55 PM
Yep , I'm wrong again. Man those part numbers are long. The bag the OP needs is 3017. 20 washers there.
Thanks Ron
RV-10 SOLD
RV-14 Flying
AirCam flying
11-24-2013, 05:50 PM
Thanks Ron. I finally found them.
Ken Stockman
Midland, MI
N73XP
