Old 11-22-2013, 12:15 PM
jtrollin jtrollin is offline
Default Rolling steel tube
Anyone know where I can get some 1" 4130 rolled? I need to modify my sticks in my RV-10 and need a piece of steel tube rolled so it has a radius to it to match the existing stick bend. Tried about 20 local places with no luck.
thanks,
John - Leesburg VA
RV-10
http://websites.expercraft.com/jtrollin/
Phase 1 Complete
Vans Builder Number: 40923
798HJ Reserved
Old 11-22-2013, 12:37 PM
deek deek is offline
Try a local hot rod shop that does mandrel tube bending. If they have a mandrel that matches the ID of your DOM 4130 it should be easy and relatively inexpensive.
'83 LongEZ - N888EZ 3,671 hours
'89 LimoEZ - N26EZ 686 hours (sold)
A couple of Glasairs and a Lancair 320...
Next: a RV14 need something to build
Old 11-22-2013, 12:53 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Try Russ, he makes stuff for Vans----maybe the sticks??
http://www.vansairforce.com/community/member.php?u=2228
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 11-22-2013, 01:53 PM
N15JB N15JB is offline
If this is to increase the clearance between your stick and the bottom of the panel, some builders have had muffler shops bend a smaller radius in the stick. Others have used the HF bending kit to do the same.
Jim Berry
RV-10
Old 11-22-2013, 03:02 PM
you have to be carefull of the dies you use, and how much of a bend you make. You can kink the tube---which is bad.
Ridgeland, SC
Old 11-22-2013, 03:16 PM
Russ McCutcheon's Avatar
Russ McCutcheon Russ McCutcheon is offline
He asked, I could not help him, don't have a way to roll the tubing.
Russ McCutcheon
@rv4welder on Facebook
russmccutcheon@gmail.com
We build many of your RV weldments.
Old 11-22-2013, 03:52 PM
Originally Posted by TS Flightlines View Post
you have to be careful of the dies you use, and how much of a bend you make. You can kink the tube---which is bad.
If a good ball mandrel is used bends at r=1.5D can be easily made, even in thin wall tubing. If you can't find a good horizontal bender with ball mandrel tooling see if you can find someone with a Pines 3T vertical compression bender; the wing dies on a 3T can do an okay job of simulating a "rolled" curve.
Old 11-23-2013, 05:51 PM
FredMagare FredMagare is offline
It seems that one might be able to mitigate the tendency of a tube to kink while bending it by first filling it with sand. I've never bent tube before though....
Fred Magare
GySgt, USMC (Ret.)
PP-ASEL, A&P
Frederic.magare "at" gmail.com
RV-9A Firewall Forward
[Engine purchased]
Old 11-24-2013, 08:11 AM
Marc DeGirolamo's Avatar
Marc DeGirolamo Marc DeGirolamo is offline
Default Bending 4130
Unless you have the proper mandrels don't even try to bend this stuff.....it will kink no matter how careful you are.....that's been my experience anyway...
Marc DeGirolamo
Canadian..Rv-4 Flying
VAF # 144
Old 11-24-2013, 08:19 AM
Default Nope wont work
I tried that..... Even welded a bolt onto one end to pack the sand......result 'kink'. . This procedure does work with mild steel pipe though.
Maybe for a bend of a few degrees it would turn out OK( you are just likely not seeing the deformation) ??
Even when heated there is still a lot of strength (resistance) to overcome when bending.....and the sand deforms too easily.....thats my theory anyway!!??
Marc DeGirolamo
VAF # 144
Last edited by Marc DeGirolamo : 11-24-2013 at 08:20 AM. Reason: Remove unwanted letter
