Old 11-18-2013, 08:05 PM
jswareiv jswareiv is offline
Default Nutplates on Inboard Wing
Wondering how everyone dimpled the nutplates on the inboard wing, Section 16, Top Wing Skins(New Numbering, I think the old was 14). Did you dimple through all three pieces together, the top skin, the doubler and the rib, or separate out the parts and just dimple the top skin for the #8 screw. If so, how did you address the wing walk doubler? I had someone suggest to separate them, then drill an oversize hole for the dimple to sit in, in both the wing walk and the rib. Suggestions? Also, what did y'all use as .032 skin or scrap to test the fit of the mating of the two top skins? Thank you for any help you can give.
Stoney
First RV-14 Flight 04/17/2016
Serial #140087, N214SW - Sold
Old 11-19-2013, 07:46 AM
M McGraw's Avatar
M McGraw M McGraw is offline
I countersunk the inboard top skins and dimpled the bottom inboard skins. With one exception. The aft most top inboard skin hole is dimpled.
Marvin McGraw, 5TN4
RV-14. #140039 Complete
Flight hours: 500+
2020 Dues Paid
The Dues Paid note is a reminder for me
Old 11-19-2013, 08:39 AM
rvbuilder2002's Avatar
I think this is (should be) what the construction manual describes to do.
Scott McDaniels
Hubbard, Oregon
Old 11-19-2013, 09:20 AM
Default Countersinking for Nutplates
O.K., it doesn't say specifically to CS the other holes in step #4, but I guess because it calls out that one nutplate to dimple, the "assumption" is to CS the others. Thanks.
Stoney
Old 11-19-2013, 09:49 AM
propsync's Avatar
propsync propsync is offline
There seems to be confusion on this part.
If I am understanding what you are asking, you do not dimple any of those parts. The 4 inboard ribs (top), the doublers, and the skins are not dimpled at all, including where the nutplates are. You countersink the top skin only in those locations. The only dimple there should be is at the very trailing edge of the top skin and that is the center hole for the last nutplate.
See where I have circled in this pic, that is the only hole that is dimpled.
Tom B
Tampa, FL
EAA - Tampa Exec Airport
Old 11-19-2013, 10:41 AM
Andrew M's Avatar
Andrew M Andrew M is offline
Default Looked ahead
and dimpled everything prior to assembly. The nut plates are secured to the rib only.
Andrew Miller
A&P, IA
-9 empennage
Wings arrived 12 JAN 13
https://plus.google.com/photos/11360...J-TuJPsmOONzQE
Old 11-19-2013, 12:44 PM
So you are CS the holes for the #8 screw and all of the rivets for the nutplates (different sizes of course), except the one at the bottom and that one is getting dimpled. So CS the parts in place, then separate, debur & prime. Correct?
Stoney
Old 11-19-2013, 12:47 PM
This not correct.
A Van's Aircraft design standard is that nutplate attach rivets never get buried (making them difficult to replace if needed).
Scott McDaniels
Hubbard, Oregon
Old 11-19-2013, 12:49 PM
I prefer to do it after final assembly/riveting.
Machine countersink deep enough for a #8 screw dimple.
Scott McDaniels
Hubbard, Oregon
Old 11-19-2013, 01:11 PM
propsync's Avatar
Agree. I simply followed the order of the plans. After everything (skin) was riveted, that's when I countersunk the screw holes. It's basically one of the last steps of the entire section, (14-04 step 2).
Tom B
Tampa, FL
