  #11
Old 11-04-2006, 07:07 PM
Buzz Buzz is offline
BryanArd,,,,just this evenin, showed 2250/2275 rpm on the tack as I was takin off,,,,temp was bout 65F and field elevation is 1700ft...Chris
Old 11-04-2006, 07:21 PM
rv4dude rv4dude is offline
Default Prince Prop worth a look
I've flown a Prince Prop in a RV-3. It's a sweet thing, its built to flex flat pitch in takeoff and climb and then return to course pitch in cruise when there is less "pull". It has the curled or bent tips also to improve performance. I liked it.
Kel
Old 11-09-2006, 04:20 AM
smokyray's Avatar
smokyray smokyray is offline
Default I've tried them all...
If you are a true budget RV4 dude, call Ed Sterba, his props are the cheapest out there and work good. I ran one for 5 years. It's still flying on an RV4...
Craig Catto's are the best overall, I now run an MT 2 blade which is the best utility and matches the Catto performance. Good Luck...
Rob Ray
Old 11-19-2006, 09:59 AM
G-JIMS G-JIMS is offline
Originally Posted by RV4er
Hello all,
I need to order a prop for my RV-4. It has a 160 hp O-320-A1B installed. Because of a dough shortage I realy need to go with a wood prop. Any suggestions?
Tim
I have a performance prop that came off my rv4 as im going to fit a Hartzel CS its the old style spinner and 4" extension. 68 x 70 prop? Make me an offer!!!!! its done less than 200 hours and it was on a 0-320 its like new
Regards
James
Old 12-17-2006, 04:07 PM
rv8r's Avatar
rv8r rv8r is offline
Hi there!
If you (or others) would like to got with constant speed but have no chance to get one on your engine (mechanical or $ reasons) check this out:
V-Prop Germany
They will have one for RV's soon.
Cheers, Dirk
Dirk Schlichtenhorst, GERMANY
RV4 #4405 (flying ), D-EEES "Lady Godiva", VAF 768
Homepage: www.rv8r.com
Old 12-17-2006, 06:11 PM
Mel's Avatar
Mel Mel is offline
I believe that the "V-Prop" is only rated to 120 hp max.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 12-17-2006, 11:03 PM
jclark jclark is offline
Default MT 2-blade ...
We ran an Ed Sterba for over 700 hours. Fine prop. Fine person to work with.
Wanted to go to CS (formation + rain) but could not.
Now running MT 2-blade. Performs as "advertised" and can stand the rain. Priced like Sensenich metal but weight about same as Sterba wood so no W&B changes.
James
James E. Clark
Columbia, SC
RV6 Flying, RV6A Cowling
APRS
Old 12-18-2006, 08:07 AM
Tom McCutcheon Tom McCutcheon is offline
I just bought a Performance Propeller from Clark & Judy. First off it's a beautiful prop. It already performs much better than my Amar Demuth prop ever did. I had emailed Demuth to find out about repairing it but never got a reply.
Anyway, Clark listened very carefully to what I wanted and is very knowledgeable about props. When you buy one of his he pitches it a bit strong. Then when you get the prop and fly it you record your numbers such as static RPM, take off RPM, RPM at different altitudes and true air speeds as well as climb rate, OT etc. Then you talk to him and together you decide what adjustments you need. Then you send the prop back to him and he makes those adjustments and puts the final finish on it. This is all included in the quoted price of the prop which form my RV-4 is just over $1300.
He told me that his prop is not a constant speed prop but they refer to it as a quasi constant speed. As it's RPM increases when you level out, there is enough flex that it changes approximately 1/2 degree which he told me is approximately equivelent to about 6 inches.
Also, the Demuth prop is refered to as a plank propeller which mine had about 5 layers that were about 3/4 inch thick. My new Performance prop has almost 70 layers and empregnated with water proof glue on each side. Clark also lays in a rain proof leading edge. The prop runs very smooth and so far I'm very impressed.
Old 04-08-2008, 08:56 PM
russwagner russwagner is offline
Regards
James
James,
Hi, I just purchased a rv3 with the 150 HP but no propeller, could you give me more info on your prop so I could see if it would fit.
Thanks ! Sincerely: russwagner
