  #21
Old 11-18-2013, 06:27 AM
Mich48041 Mich48041 is offline
13 volts is fully charged, not 12.5 volts. I agree with the others that the solenoid (aka contactor) is chattering. The cause could be a bad electrical connection or a weak battery or a bad starter motor. This is what causes the chattering: the voltage is high enough to energize the contactor, but the heavy load of the starter causes the voltage to drop so much that the contactor opens up and you hear a click. Now that the contactor is open and no heavy current is flowing, the voltage goes back up and the contactor energizes again and you hear another click. This sequence is repeated over and over several times per second and you hear the buzzing or chattering.
Joe Gores
Old 11-18-2013, 07:07 AM
Valentine Valentine is offline
Default Coolant?
Make & model of engine please.
Hal
Finally sold N7HK
Old 11-18-2013, 07:31 AM
Dvalcik's Avatar
Dvalcik Dvalcik is offline
99.9% chance it is a Rotax 912 if he is building the RV12 as an E-LSA as most guys do.
David
EAA 1250 KPTW
Royersford, PA
david@rv12pilot.com
2020 VAF Supporter
RV12 #568 EAB
* Started 9/30/2011
* 1st flight 8/30/12
http://www.rv12pilot.com
Old 11-18-2013, 07:51 AM
ChuckC ChuckC is offline
Building ELSA. So, using the Rotax 912.
Chuck Carlson
120445
Old 11-18-2013, 08:14 AM
flion's Avatar
flion flion is offline
Originally Posted by ChuckC View Post
Yes, the battery is fully charged showing 12.5 on charger and Skyview. Did check all the wiring connections - visually and tugging, and, they all appeared solid.
With most advice pointing to the battery or connections, you should test before you replace. Looking at the connections and tugging on them is not the same thing (though it is true that tugging can sometimes complete a poor connection, temporarily). Get out the multimeter. Test resistance through the connections and voltage at each point.
I don't know the -12 electrical system, but in most aircraft I would check that the ground is good at all points, that there aren't any connections with a high resistance, that resistance through the solenoid is high until engaged, and that the activation lead is seeing system voltage (to see voltage at any point, put a probe on the connection and the other probe to ground). I've seen bad solenoids but I've also seen bad grounds or switches fail to provide enough power to activate the solenoid, which results in the intermittent "machine gun" chatter that you describe. Likewise, not enough power to the starter can also cause an intermittent sound but I don't think it would sound like it was on the firewall. You'd also probably see the prop move slightly each time you activated the starter.
EAA Technical Counselor #5357
Old 11-18-2013, 08:23 AM
AWakem8 AWakem8 is offline
Default Brrrrrrrrr=Solenoid
Your battery is not fully charged or you have a poor connection. The "Brrrrrrrrr" sound is the starter solenoid contacting and releasing rapidly. I would suggest charging the battery first and then try again. Remember the KISS principal. I live by this and most of the time it keeps me out of trouble.
____________________________
Andy Wakem
Belfast, Maine
Study phase RV-8 Preview Plans
2014 donation made
Old 11-18-2013, 08:27 AM
txaviator's Avatar
txaviator txaviator is offline
Default I'm no expert, but:
I am voting that the battery (despite showing 12-volts) still doesn't have enough charge. As a result, the solenoid is chattering.
Gary Robertson
Arlington, TX
RV-12 Built / Sold / Flying
Currently Flying: Cessna Skyhawk 172
Rebuilding a true barn find J-3 Cub
Old 11-18-2013, 08:35 AM
ColoRv's Avatar
ColoRv ColoRv is offline
Just another WAG here, but is the engine grounded?
RV-8 Flying
1,235th flying RV8
SARL Race#95
SnF Homebuilt Judge
Old 11-18-2013, 08:44 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Originally Posted by E. D. Eliot View Post
Are you sure that your battery is fully charged? Could be as simple as using a fully charged battery.
This.
To me, sitting in the cockpit, it sounds like something is battering the firewall really rapidly - fifty times faster than you could do with a hammer.
Starter solenoid.
They chatter due to either low battery voltage, or bad connections not letting full battery voltage through.
And this. Bad grounds are the overall biggest cause of electrical gremlins I have ever seen in half a century of wrenching of cars, boats, and planes.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 11-18-2013, 12:28 PM
Warden Warden is offline
Starter drive. Check negative battery connections. Use internal/external star washers between battery terminal and cable (yes, between terminal & cable!) to achieve good electrical contact. Also, starwasher between battery negative cable and grounding point on engine.
