Old 11-12-2013, 02:41 PM
gmpaul gmpaul is offline
Default Side tone problem
I have sl 40 and a ps1000 audio. The problem is side tone which is blasting loud during transmitting. Volume and clarity is great till I key the mike. I sent the ps1000 in for service and they found nothing wrong. When upon reinstalling the ps 1000 every thing worked fine for one flight. Now it's back to turning my earphones all the way down to be able to stand it and you can still hear the over driving. Any ideas what I should look for when I drop my panel and start probing around?
Old 11-12-2013, 02:45 PM
You know the sidetone level can be adjusted via the SL-40s menu, right? What level is it set at now? What happens if you turn it down to zero?
Old 11-12-2013, 02:53 PM
MarkW's Avatar
MarkW MarkW is offline
Bob is correct, sidetone can be handled from either the radio or audio panel.
It is usual for the radio to handle it and the audio panel sidetone to be disabled. A setting on the radio is very easy in the setup mode.
Also make sure you don't have your headset configured to mono if the audio panel and jacks are stereo.
Mark
RV9 - N14MW - Flying
G3X - ECI Titan I0-320
Catto three blade prop
http://www.mykitlog.com/MarkW
Old 11-12-2013, 03:10 PM
mikehoover's Avatar
mikehoover mikehoover is offline
I have a PS PAR100EX/SL-30 set up. My SL-30 was blasting me in the sidetone once I had finished troubleshooting an antenna issue with it, so I tuned the sidetone setting on the SL-30 way down to around 15 and that solved the problem. 15 might be a bit low, so I will adjust it up some when I get around to it - but, much much better.
Mike Hoover
Columbia, SC
www.aclog.com/rv-9a/
www.eaa242.org/
N194MH first flight on 08-26-12
Old 11-12-2013, 04:34 PM
Andy J Andy J is offline
Setting the sidetone to zero slaves it to the volume knob, which is nice because if you don't hear yourself when you transmit you likely won't hear any answer either, like when your pilot passenger fiddles with the volume when your head is turned.
Andy Johnson
RV-12: Oshkosh 2012 "Outstanding Workmanship"
RV-6: Bought Flying - "She's a good ole bird"
-PAID 2014-
Old 11-12-2013, 04:35 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
In what unit/s??
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 11-12-2013, 05:26 PM
In what unit/s??
Sorry Mike, I don't know what units. The sidetone level seemed comparable to the recieve audio level when I had an SL40 configured this way.
Per the SL40 Pilot's Guide, page 12, "The range is from 0 to 255", and "Setting the value to 0 slaves the sidetone level to the volume control knob".
Andy Johnson
-PAID 2014-
Old 11-12-2013, 07:00 PM
Mike S's Avatar
Senior Curmudgeon
OK, you were talking about the SL 40. I would assume the SL 30 is the same.
It was not clear if you were talking about the Garman SL's, or the PS PAR100EX ----------thus my prior question.
Mike Starkey
VAF 909
Rv-10, N210LM.
Old 11-12-2013, 07:10 PM
Rupester Rupester is offline
Default Same problem
Over the past year, I 've turned down the sidetone level on my SL-30 twice, and still need to turn it down more. Mine does not go to 255 ... I don't have the manual close-by, but I think the max is either 50 or 100. Presently, mine is set to something below midrange on the SL-30 adjustment.
Terry Ruprecht
RV-9A Tip-up; IO-320 D2A
S. James cowl/plenum
(Dues paid thru Nov '18)
