11-06-2013, 07:37 AM
True takeoff and landing numbers of rv7/9
My plan is to fly my airplane (when completed) from a grass strip on my farm. I have 1,200' of grass to land on with trees on each end. I could easily have trees removed for additional clearway for approach/departure and plan on doing so. My main question is, regardless of your opinions on which engine is the best, how accurate are the performance numbers that are posted on Van's website. My background: I am a CFI,CFI-I, MEI, ATP, airline captain with over 7k TT and ZERO time in RV's. I have enough experience to understand I still don't know it all and really appreciate the help from you guys with the RV knowledge.
11-06-2013, 07:44 AM
1200 feet with trees / obstructions will be a challenge. The airplane will do it, but you will have to do it perfect every time.
I fly a -7 and a -9 off 1800 ft with a 50 ft obstruction on one end and a clear approach path on the other. Plenty of margin on the clear approach. It's difficult on the obstructed end.
You'll have to throw out your airline stabilized approach with power to a 10,000 ft runway training.
Jeff Rhodes - Taylorsville, GA
RV-9, 7 - going fast
BC-12D - going slow
jrhodes@v1salesmgt.com
11-06-2013, 07:46 AM
Van's numbers very realistic. For further info on short/soft/obstacle clearance performance, search the archives here. Good discussions with some pearls of info, if you can wade through the noise. BTW, where's your farm (range of density altitudes)? Get the -9 with a CS -360 (or speed brakes!), and you'll have no problem.
numbers
From my experience Van's numbers are pretty accurate. Everything has to be as Van describes for the numbers to work though. It hasn't always been that way for me, but in ideal conditions, his numbers are very, very close.
Just for the sake of butting into your business in a polite way......I'm sure you will remove the trees. 1200 feet open on both ends will work if you always pay attenetion. Having the credentials you have, I'm sure you always will.
11-06-2013, 07:56 AM
I have every intention of having trees removed from both ends. I definitely don't want to crumple up an airplane. I think I can get an easy 300' added to either end to get around 1800 total length. BTW I am in southeast AL with field elevations in the 340-400' range.
11-06-2013, 08:04 AM
When solo and smooth air... 400' rolling distance is no problem with a good approach.
Lots of good youtube videos if short field RV landings. Some are too crazy but most are safe.
Sid Lambert
RV-7 Sold
RV-4 - Flying - O-320 Fixed Pitch - Red over Yellow
11-06-2013, 08:19 AM
shimuneka, I'm kinda like you. I bought my RV-6 with VERY little light airplane time. Mine didn't have a checklist, POH, performance data of any kind, etc. I'm working on some of that for mine now. It's slightly unsettling to have no TOLD data, but it's normally not an issue.
With that said, my airplane with a FP prop and 150HP O-320 varies significantly based on conditions of course. Somewhat more than I might expect, likely due to the FP prop which I'm just not used to yet. At sea level or close to it on a hard surface it'll be close to the Vans numbers. Departing two-up from long grass at 2100' on a warm day it's a totally different critter than down at your altitudes and on pavement. As I said, I'm still getting used to it, and collecting data for some basic TOLD guidelines.
You're in LA (Lower Alabama  ) so you're GTG altitude wise there. Lose the trees and you probably won't have an issue once you adapt to the airplane, even off the unimproved surface. The 160 hp CS RV-7 I flew with Mike Seager is a totally different animal in the initial takeoff roll than the 150 FP airplane, especially in the grass. It just accelerates much harder. Landings shouldn't be an issue.
Disclaimer: I'm very to the type, so take the above with a grain of salt...
Doug
11-06-2013, 08:31 AM
about getting IN...
maybe I am stating the obvious, but at least for the -9 FP, tendency to float especially when you are light will be significant if you have ANY excess airspeed at all. that extra wingspan coupled with any excess airspeed will probably send you around if you cross the threshold at anything over about 60 mph. my opinion only, and based on my airplane only...
11-06-2013, 08:54 AM
You will find this topic has been discussed a few times - eg "I and building X and want to fly off of a grass strip that is <number less than 2000'> long".
The decision is yours and yours alone. What follows is my situation ..
Under ideal conditions, I achieve the Vans numbers. I rarely enjoy ideal conditions - a couple knots too fast or any variance to the wind or a bird or or or ...
I fly an fixed-pitch RV-8 solo off of a pretty smooth 1900' grass runway with trees at one end. It's hard to get "everything" just right. On a good day, if I am no faster than 64Kts on final (1.3x stall and not behind the power curve), I can be down and rolling to a stop by mid field when landing toward the trees. BUT, it does not take much to use 2/3rds or more. Landing over the trees I can expect to use 2/3rds. That means 1275' with no margin for error.
With the exception of a lone Cherokee, no one but me has ever landed coming over the trees and no one but me has ever taken off toward the trees. There have been a number of RV pilots who have visited. Some has CS props. There have been 9A, 7A, 6A, 7, and 8 representatives. The CS guys tend to do well; the 9A driver is a very experienced pilot with short grass strips. All are still rolling past mid-field and on the brakes.
If I had a shorter field with the trees at one end, I'd have more no-go flying days.
11-06-2013, 08:57 AM
What Don says
Is exactly right with the FP RV-9 and a short field. The approach over the threshold has to be on airspeed target or you will eat an 1800 ft runway up.
DRRhodes
2020 VAF Supporter
RV9 N908DR
