Go Back   VAF Forums > Avionics / Interiors / Fiberglass > GPS
Old 11-05-2013, 02:04 PM
CopterJohn CopterJohn is offline
Default Some approaches vanished from Garmin
RV Folks,
We aware that GPS approaches to several smaller airports have been dropped by Garmin from the Jepp IFR database. So while you may have a valid paper or electronic chart, the approach will NOT be in a Garmin IFR approved unit.
These include some popular airports like Osage Beach, MO. Waseca, MN, Wisconsin Dells, etc. Several 3 characted ID airports also affected. Here is a list of dropped approaches.
Copter John
35A, RNAV 05
35A, RNAV 23
3MY, RNAV 18
42A, RNAV 03
4D0, RNAV 09
4J5, RNAV 10
4J5, RNAV 28
7G8, RNAV 11
7G8, RNAV 29
8A3, RNAV 03
9G3, RNAV 07
9G3, RNAV 25
D95, RNAV 18
D95, RNAV 36
I68, RNAV 19
K15, RNAV 14
K15, RNAV 32 KACQ, RNAV 33
KAHH, RNAV 18
KBUU, RNAV 11
KBUU, RNAV 29
KCDI, RNAV 22
KCIR, RNAV 14
KDLL, RNAV 19
KGTG, RNAV 30
KHEZ, RNAV 18
KHEZ, RNAV 31
KHEZ, RNAV 36
KHTL, RNAV 09
KHTL, RNAV 27
KIOB, RNAV 03
KJVW, RNAV 30
KMMK, RNAV 36
KMMS, RNAV 20
KMNM, RNAV 32
KMXA, RNAV 18
KOJA, RNAV 35
KOMN, RNAV 26
KOQW, RNAV 15
KTEW, RNAV 10
KTEW, RNAV 28
KWAL, RNAV 10
MO3, RNAV 19
PACX, RNAV 01
PAHO, RNAV 04-Y
W96, RNAV 11
W96, RNAV 29
Old 11-05-2013, 02:27 PM
colojo's Avatar
colojo colojo is offline
Any idea why they were dropped?
Joe Zuffoletto
RV-8 (flying)
Fullerton, CA (KFUL)
2021 dues paid!
Old 11-05-2013, 02:50 PM
Garmin deemed them non WGS84 compliant. FAA regional offices here looking into the lack of notice to airmen.
Old 11-05-2013, 03:17 PM
Radomir's Avatar
Radomir Radomir is offline
I believe those are the ones that were coded in the database with the 0 degree glidepath angle.. Garmin can't handle that so they dropped those..
Radomir
RV-7A sold
Old 11-05-2013, 03:49 PM
Radomir is correct
Old 11-05-2013, 03:51 PM
FORANE's Avatar
FORANE FORANE is offline
Default Is this for WAAS only?
I just fired up my non-waas G 430.
35A, RNAV 05
35A, RNAV 23
Both appear, both are selectable, both appear on map after selecting them.
I have the current Jepp data card in the 430.
What gives?
Old 11-05-2013, 04:07 PM
Radomir's Avatar
Yes it affects WAAS units only.. because this happened when they introduced LP minimums at certain airports (such as 35A).. You can't do LP minimums with a non-WAAS unit..
Radomir
RV-7A sold
Old 11-13-2013, 09:22 PM
For anyone following this thread, Garmin reported back to us that this is a software issue across the WAAS platform that will require updates to certified units. They do not expect code revisions until summer of 2014.
Old 02-15-2014, 07:04 PM
Dan B Dan B is offline
Default Garmin 400W/500W Software Upgrade 5.10
Garmin announces software upgrade version 5.10 on Feb 6. Two of the changes addresses RNAV w/LP mins. This software upgrade should allow RNAV LP that don't have a Vertical Descent Angle (VDA) charted to be included in the nav database again. This issue has affected about a hundred RNAV approaches, so far.
There are a multiple of other changes with this software upgrade.
See Garmin support/ service alerts/ aviation service alerts
http://garmin.blogs.com/files/1403a_adsn-1.pdf
Dan Burdette
Skyview, Garmin GTN750xi, TT Gemini AP
RV-9A, IO-320
Guthrie-Edmond Rgnl, OK (KGOK)
________
Old 04-01-2014, 02:14 AM
FORANE's Avatar
Anyone know if there is a fix for this issue yet?
I have a Garmin GTN 650 which lacks these approaches.
Lancair 235/340
RV-9A (2013 - 2016)
