  #11
Old 11-01-2006, 12:41 PM
sprucemoose's Avatar
sprucemoose sprucemoose is offline
The Skytec issue has been done to death already, there is plenty in the archives to look at. In a nutshell, a Skytec may work just fine on an engine with a heavy prop and a big battery. On our engines, with (often) lightweight props and (usually) small battery, the Skytec is not suitable.
Edit- I should clarify- I am refering to the Flyweight Skytec model. The hi-torque ones are built with wound-field motors (like the B & C) and should work much better.
Jeff Point
RV-6, RLU-1 built & flying
Tech Counselor, Flight Advisor & President, EAA Chapter 18
Milwaukee
Old 11-01-2006, 02:31 PM
jbDC9 jbDC9 is offline
If you're leaning towards a Sky-Tec Hi Torque HT, you might try these guys;
http://autoexpress.safeshopper.com/2212/15820.htm?640
On their home page the price is listed at $249, but their eBay store price is $225.
http://stores.ebay.com/Auto-Express
They're listed as airboat or experimental starters, for liability reasons I'm sure. But, compare them to the pics of the HT Sky-Tec, and besides missing the FAA/PMA sticker, I can't tell them apart. They look identical and this one is 200 bucks cheaper than the Sky-Tec.
Old 11-01-2006, 06:44 PM
Radomir's Avatar
Radomir Radomir is offline
Good find, John.. thanks for the link
Radomir
RV-7A sold
Old 11-01-2006, 10:09 PM
Walt's Avatar
Walt Walt is offline
Default Thanks for all the help...B&C wins
I bit the bullet today and ordered the B&C. I have been very pleased with the alternator/reg from them and I believe they provide a very high quality product. I'm also a Nuckle subscriber and like to support the small business owner whenever possible. I think the new inline from skytec would have been the next best choice but for an extra $50 I got the BC. Thanks everybody for all the input.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 11-02-2006, 04:02 PM
Superior-Sales Superior-Sales is offline
Default Why change?
The problem with the Skytec PM and LSE ignitions was caused by the computer becoming confused and changing the timing, sometimes causing essentially a backfire, if a power drop occured which was below that required by the LSE system to function. This backfire could break the casting on the nose of the starter. If a person had a low battery, poor cables, whatever, the starter draws so much it could cause this condition. All it required was a software change which Klaus told me he incorporated in all his systems starting in January 2005, so although I don't think Skytec has changed it's position warranty wise, you shouldn't have to change your starter.
Knick Curtis
Old 11-02-2006, 05:52 PM
LifeofReiley's Avatar
LifeofReiley LifeofReiley is offline
Thumbs up Good Company and Nice Starter
I bought one of these starters over a year ago. Nice product at a great price. These are Brand New Starters and they sell a lot of them.
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
Old 11-05-2006, 07:58 PM
Gary Bricker Gary Bricker is offline
Smile Gary Bricker
I have a Sky Tec on a IO470 cont. and it is great. I know of plenty of folks that have them also and no problem. I have a new IO360 from Aerosport and it came with a Sky Tec and Bart's word is as good as it gets. I also know the folks at Sky Tec and they are as upstanding as Bart. B & C could be as good also but when I have good luck with a product I don't change.
Old 11-06-2006, 04:39 PM
gmcjetpilot's Avatar
gmcjetpilot gmcjetpilot is offline
Default I liked my LS/PM Sky Tec
I bought one of those autoexpress starters out of curiously as a spare. I have not used it and concure it LOOKS LIKE a Sky Tec HT, but it's different. I'm pretty sure it's a permanent magnet starter. The Sky Tec HT is a wire wound starter.
I concur that the Sky Tec makes great products and has good support. Their customer service is excellent in my opinion. Their bargain priced original LS/PM permanent magnet "flyweight" does a great job. I flew with one on my RV-4 for 900 hours with no problems.
Here is a short list:
Sky Tec
LS/PM original Flyweight $350 (7.8 lbs) (Permanent Magnet)
HT sky tec original Hi-torque $425 (8.4 lbs) (wire wound)
NL hi-torque, in-line, shear pin $525 (9.4 lbs) (wire wound)
B&C $550-$580 (weight ? like sky tec HT, but $125-$155 more)
Autoexpress $250 (9 lbs) (Permanent magnet?)
Yes the LS/PM permanent magnet starter does use more juice and needs a good battery and good wiring but nothing special. Yes, RV's with light props, super high compression engines or electronic ignitions (which can be affected by low voltages) may be better served with a different starter, like the Sky Tec HT or NL models.
There are well documented solutions to address electronic ignitions on Sky Tec's web site ( http://www.skytecair.com/EI.htm ). I least the current draw below, and the B&C draws almost as much as the LS/PM sky tec!
The NL is better, but was made for planes that could not fit the LS/PM or HT, not because there was a problem with the other models. They also added a shear pin to the design. Most RV's can use any of the models.
B&C is just over priced IMHO and offers nothing more than the SkyTec HT or NL. If you want the deluxe, get the NEW Sky Tec NL starter, it's still cheaper than the B&C. Sky-Tec replaced B&C for the OEM starter on Robinson Helicopters. The LS/PM will serve most RV'ers well, except the most picky (and you know who you are) RV'ers.
Peak current draw for different brands of starters:
Sky Tec LS....... 320 amps
B&C................. 298 amps
Magnalite.......... 282 amps
Sky Tec NL....... 236 amps
Lamar.............. 226 amps
Prestolite......... 194 amps
PC680 odyssey can pulse discharge 680 amps for 5 seconds to 400 amps for 30 seconds. A fully charge PC680 can feed a skytec LS/PM easily, but the voltage drop needs to be kept to a min. Key is a good ground and short battery to starter wire/cable of sufficient gauge AWG (#2 min). This will minimize voltage drop during cranking. My engine starts in a couple of blades or second.
Note, kick backs can KILL ANY starter and ring gear. Kick backs are NOT normal and should not happen. When they do, most of the reasons have nothing to do with the starter. http://www.skytecair.com/Kickback.htm
At $580 B&C is nice and if that is what you want or have its a good choice. The comparable Sky Tec HT or the better NL starter, both are all ball bearing and comparable to the B&C at less cost. The LS/PM is much maligned, but it's characteristics and limitations are fine for most installations. It is the lightest and least cost starter, but not as forgiving of electical and engine issues.
George
Raleigh, NC Area
2020 Dues Paid
