Old 11-03-2013, 12:41 AM
wvshooter wvshooter is offline
Default Flamemaster in quart can
This might seem obvious but thought I'd ask.
If you buy the quart can from Van's is it possible to mix a small amount for a small sealing job then close up the containers and be good to go for another sealing job at a later date? Assuming of course that you don't exceed the product's shelf life.
I am referring BTW to the fuel tank sealant product, a Proseal substitute, manufactured by Flamemaster.
Old 11-03-2013, 03:40 AM
-goose -goose is offline
Yes you don't have to use it all at once. Just mix up as much as you need each time. Keeping the containers in the freezer reportedly extends the shelf life.
John Keen
RV-7 flying
Gold Coast, Australia
Old 11-03-2013, 06:06 AM
DonFromTX's Avatar
DonFromTX DonFromTX is offline
And at sometime you will probably run out of the black stuff before the grey stuff.
A&P, PP-SEL, Pathological Flier, EAA Technical Counselor
EAA Chapter 595 President,http://www.595.eaachapter.org/index.htm
Retired US Army Officer
Old 11-03-2013, 06:08 AM
scard's Avatar
scard scard is offline
Absolutely! I always have a quart can of Flamemaster (proseal) and hardener in the freezer. It is just so useful to mix up a tiny little glob for all kinds of stuff. And just in case you were wondering, it works just fine many years after expiration. Not that I would use old stuff on a new set of tanks.
Scott Card
CMW E-Lift
Old 11-03-2013, 08:36 AM
Thanks for the replies. Looks like I'll go the quart route.
Old 11-03-2013, 06:14 PM
jarhead jarhead is offline
We do it that way at work all the time. The Feds don't care, as long as we stick to the manufacturer's shelf life limitations.
Personally, I take pride in estimating how much proseal I'll need for a job, and mixing only enough to get the job done, with as little as possible wasted. Along with the professional pride, I figure it's good training if the day ever comes that I can make the jump from "RV dreamer" to RV builder, and I'm paying for the stuff myself...
Ken
Helicopter mechanic (A&P)
USAFR KC-10 Boom Operator, on final approach to retirement
My RV-9/8/7 dream may be on life support, but it ain't dead yet!
