Old 10-30-2013, 10:16 AM
Dorfie Dorfie is offline
Default Perpendicular drilling, free hand
Does anybody have an easy, practical way to drill perpendicular to the surface using hand held drill. I find it especially challenging drilling the door hinges (RV10) from inside! Any slight angle and the screw heads on outside highlights your mistake.
Thanks.
Johan
Dorfie
RV10 Flying, N245JM
2020 dues paid with a smile
Old 10-30-2013, 10:22 AM
N15JB N15JB is offline
I would just eyeball it best as you can. If you don't like the result, glass it in and try again. Once completed, those screws will only be visible to NBA players.
Jim Berry
RV-10
Old 10-30-2013, 10:25 AM
Ken Martin Ken Martin is offline
Do you normally centerpunch first before drilling? This helps tremendously and the only other idea I would have is to create a drilling fixture if you feel it's worth the trouble.
Ken
?Aviation is not so much a profession as it is a disease.? Anonymous
Building an RV-7
Empennage complete, fuselage 75%, wings 75%.
Old 10-30-2013, 10:35 AM
dougmattson dougmattson is offline
Try one of these http://www.aviationpros.com/product/...70-drill-block
9A flying
Old 10-30-2013, 11:00 AM
larrynew's Avatar
larrynew larrynew is offline
I like to use this. In tight spots I've used the center guide without the plastic housing.
http://www.averytools.com/prodinfo.asp?number=25783
Larry New
RV-7A - Built, flying 900+ hrs
RV-10 - Built, flying 2.9 hrs
??? - RV-12, Subsonex
48 States in 7 Days!
VAF Paid - Annual Autodraft
stinson pilot's Avatar
stinson pilot stinson pilot is offline
We use these a lot in the industry.
http://www.ebay.com/itm/7-PC-Drill-B...-/141097447572
Edit: Larry beat me to it..
Doug
1947 Stinson 108-2
Steen Skybolt
Old 10-30-2013, 11:49 AM
Bavafa Bavafa is offline
Nice!!!!
I think I need to build another plane just so I can use these
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Flying
Dues paid
Old 10-30-2013, 04:11 PM
When drilling into something shiny like aluminum, look at the reflection of the bit and the bit itself - they should be a straight line, not a 'V'. You need to look both from the back and from the side.
Old 10-30-2013, 05:03 PM
DanH's Avatar
DanH DanH is offline
There is always some way to make a jig.
http://www.kitplanes.com/issues/30_1...s_20873-1.html
Sadly, it is "subscriber only" content...but you can cure that
Dan Horton
RV-8 SS
Barrett IO-390
Old 10-30-2013, 07:56 PM
Greg Arehart's Avatar
What Bob said works, provided the aluminum is not bent or curved.
Greg
Greg Arehart
N 7965A
