10-19-2013, 10:50 AM
W818 Aileron pushrod (dwg15a)
Hey all-
I' putting together the aileron pushrods... And have a quick question about the w818 (small pushrod). The plans note the option to weld the ends on this push rod... I'm contemplating having this welded. Are the any draw backs to having this welded together? Or better yet pinned & welded. Thoughts? Thank you!
10-19-2013, 04:45 PM
Aileron Rods
Dan,
I initially attempted to set rivets on the end of the pushrods, but had trouble setting the rivets to my satisfaction. The small diameter rod encouraged the rivets to roll over- at least for me. So, I headed down to the airport and had an A&P weld the ends in place- Much more peace of mind that the rod ends won't slip out.
Jim Diehl 7A
10-20-2013, 11:28 PM
I had no problems riveting them. Quick & Easy.
10-21-2013, 09:52 AM
To do it again I would have TIG them. Some have a little clearance issue with those rivets when installed in the wing.
10-21-2013, 04:46 PM
I used the rivets and had no issues, go slow, secure the job well so that it does not move.
Cheers
Eddie Seve
Sydney Australia
First Flight 16th July 2012
RV-7 Phase 2, 30 Oct 2012
1100 hrs Feb 2020
10-21-2013, 06:00 PM
I had the clearance issue Bret refers to. The rivet heads on my p-rods would actually hang up on the edge of the rear spar opening. Called Vans; they said to grind the hole in the rear spar bigger. That solved the problem. If the p-rod was welded, I could have left the holes as is.
Terry Ruprecht
RV-9A Tip-up; IO-320 D2A
S. James cowl/plenum
(Dues paid thru Nov '18)
10-22-2013, 05:02 AM
Daniel,
I had mine welded and then stuck in one rivet for good luck
Jack
Smilin' Jack & Anita Hunt
N507H RV7, KJZP Jasper, GA
EAA690
APRS/ WB4JKY
Retired Corporate Pilot CFI-AI, MEL
CE500, LRJT, HS25, C650, SBJT, CL60
Hunt Aviation, LLC.
Pilot Service, IPC's Biennials.
Comm Glider
