10-31-2006, 09:33 AM
IO390 FUEL CONSUPTION
HI ALL,
JUST WONDERING IF ANYBODY IS USING A IO390 (210HP ENGINE). I WOULD LIKE TO KNOW HOW THIS ENGINE IS PERFORMING FUEL CONSUPTION LET'S SAY, AT 8000' AND 75% AND 55% POWER. IS THE CONSUPTION CONSIDERABLY HIGHER THAN A TRADICIONAL IO360 180HP ENGINE?
THANKS ALL
HENRIQUE CASTRO
10-31-2006, 09:54 AM
Scott Farner is in Phase one at Chino with his IO-390x-- I'll check with him. Or if any of the Chino guys read this they see him regularly.
10-31-2006, 10:49 AM
Horses Eat
Originally Posted by henriquerv9
HI ALL,
THANKS ALL HENRIQUE CASTRO
For a guess you can ratio the HP 210/180=1.16 to get an approximate fuel burn. Horse power: Horses eat. The more ponies the more fuel. It is basically a function of HP.
You could throttle back and burn the same fuel as a 180 HP, e.g. same airspeed, but apples to apple 100%, 75% and 55% power you will make 16% more power and burn 16% more fuel. Yes?
Compression ratio is higher with the IO390 and should be more efficient. So the HP ratio may be off a little in favor of the IO390. Also since the IO390 is really closer to a IO360 angle valve it would be better to compare those two engines.
Dan has a IO360 angle valve and flys w/ LOP operations often and gets great reported fuel econ. However if you are putting a XIO390 you probably can afford the fuel. Its only money you can't take it with you, why make the kids rich when you die.
George
Raleigh, NC Area
2020 Dues Paid
10-31-2006, 11:19 AM
I don't have any good numbers yet as I have been pretty conservative with the mixture. I haven't ventured down to 55% yet; still breaking in the engine, but at 75% and 8000 DA, I'm around 12gph.
Scott
10-31-2006, 01:57 PM
IO-390 compression ratio
The compression ratio I was quoted by Barrett for an IO390 was 8.7:1. This is a LOWER compression ratio than most IO360s I've seen in RVs.
10-31-2006, 02:47 PM
The IO-390 compression ratio is 8.9:1 Don't know what the actual fuel consumption really is, but at 75% leaned to BSFC of .52-.53, you should see right around 13 GPH, 10 @ 55%.
Allen
10-31-2006, 04:18 PM
Picking a Nit
If you take two engines, identical except for displacement (same CR, prop, etc) and run them at the same HP, the larger one will have greater pumping losses and therefore, all other things being equal, will be less efficient. This is pretty much the same as the observation that the same RPM and MAP will give more HP at a higher density altitude, assuming the same RPM and MAP can be reached at the higher altitude. The reason is the resistance offered by the throttle plate. I don't know if this is a big deal, but it's fun to think about these things.
H. Evan's RV-7A N17HH 240+ hours
"We can lift ourselves out of ignorance, we can find ourselves as creatures of excellence and intelligence and skill. We can be free! We can learn to fly!" -J.L. Seagull
Paid $25.00 "dues" net of PayPal cost for 2015, 2016, 2017 and 2018 (December).
This airplane is for sale: see website. my website
10-31-2006, 08:04 PM
Fuel burn
I have about 96 hours on my RV-7 with an IO-390 and a 72" whirlwind prop (new 74" Hartzel arrived today). I usually cruise at 11k-12k ft (airport here is at 5,800 ft) and burn 7.4 GPH at 53% power, 50deg LOP.
At sea level takeoff (everything forward) it burns about 20GPH, and at lower altitudes it's something around 10-13GPH depending on the power. I haven't flown much at lower altittudes so it's not documented.
Hope that helps.
Marc Ausman
RV-7 980 hours, IO-390, VP-X (sold)
RV-8 (flying a friend's)
Thinking about low and slow backcountry build.
VAF Advertiser - Aircraft Wiring Guide
Book to help with experimental aircraft wiring.
11-01-2006, 07:04 AM
And how fast is your RV-7 under those conditions?
Martin
Martin Gomez
Redwood City, CA
"My RV-7 is a composite airplane: it's made of aluminum, blood, sweat, and money"
RV-7 Slider QB
11-01-2006, 08:52 AM
**If you take two engines, identical except for displacement (same CR, prop, etc) and run them at the same HP, the larger one will have greater pumping losses and therefore, all other things being equal, will be less efficient. This is pretty much the same as the observation that the same RPM and MAP will give more HP at a higher density altitude, assuming the same RPM and MAP can be reached at the higher altitude. The reason is the resistance offered by the throttle plate. I don't know if this is a big deal, but it's fun to think about these things.**
Since we're picking nits... Uhh, no. The reason it makes more HP at the higher DA is that there is less exhaust back-pressure and the cylinders have a better volumetric efficiency.
