Old 10-14-2013, 01:19 PM
jacksel jacksel is offline
Default cutting the firewall
Does anyone have a good technique for cutting a clean 2" hole in the firewall for the cabin heat fitting? Cutting stainless is always a pain and I see this 2" hole as a real challenge.
Old 10-14-2013, 01:21 PM
N941WR's Avatar
N941WR N941WR is offline
Yep, it is a real PITA!
I bought two hole saws and lots of cutting oil. Turn the thing slow and keep it lubed and all will be good.
Don't forget to deburr it. SS will cut you like a knife!
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 10-14-2013, 01:45 PM
rv4ross rv4ross is offline
I used a new hole saw and had a helper back it up with a piece of wood. It did a real nice job. And watch your hands, that stuff is sharp!
Ross Scroggs
Locust Grove, GA
RV-4 #3911
Old 10-14-2013, 01:57 PM
MarkW's Avatar
MarkW MarkW is offline
Since I learned the finer art of drilling I have had no problems with Stainless.
Like Bill sayes slow speed and like Ross sayes back it up so you can put pressure. What tears the bits up is heat. When you use a high speed and low pressure it just causes friction and no cutting. If you can keep the speed down and the pressure up it will cut and create burrs. These burrs take away heat. You just have to keep it cutting.
Mark
RV9 - N14MW - Flying
G3X - ECI Titan I0-320
Catto three blade prop
http://www.mykitlog.com/MarkW
Old 10-14-2013, 03:33 PM
BillL BillL is offline
Knockout punches do a pretty good job with this stainless. Lube it good and it cuts better. HF has a manual set for $25 but the largest is only 1.25". Maybe an industrial rental would have a hydraulic version with 2" included. That makes it very quick and very clean edges.
Wear boning gloves or be ready to bleed. NEVER touch the edge to check the finish.
Bill
RV-7
Lord Kelvin:
Old 10-14-2013, 05:56 PM
agirard7a's Avatar
agirard7a agirard7a is offline
Default Lenox
Use a Lenox hole saw blade. Slow speed,pressure and cutting oil.
Al Girard, Newport, RI
N339AG
RV-9
Old 10-14-2013, 06:26 PM
alpinelakespilot2000 alpinelakespilot2000 is offline
Ditto a hole saw, but get a "bimetal" hole saw (as opposed to a cheaper plain steel hole saw, but both should be available at Lowes/HD) and do back it up with wood as suggested. I'm assuming you are doing your cabin heat valve? If so (and assuming you have not yet riveted on your firewall recess), you can clamp a piece of wood to the firewall to serve as the back up. Good luck.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
Old 10-14-2013, 10:24 PM
grayforge's Avatar
grayforge grayforge is offline
A GreenLee punch worked perfectly. Klein Tools makes one too. Just a few minutes and done.
These are expensive, so look for a set on eBay or borrow/rent a set.
Speed Is Life
VAF Donation made: 1/28/2020, My RV-7A Build Log
Old 10-15-2013, 12:26 AM
Stoo Stoo is offline
I just used my Dremel.
Stewart Willoughby
6, finishing
Old 10-15-2013, 10:51 AM
Rupester Rupester is offline
Default Rotabroach or similar ...
Hopefully, you can find a metalworking shop or friend with a set of Rotabroach hole cutters, or similar product. They cut thru the FW stainless like the proverbial hot knife thru butter. Totally amazing...takes maybe 5 to 10 seconds with a battery powered drill motor.
I also used a carbide rotary file (available at all the aviation tool houses) that was verry effective in enlarging holes in the stainless.
Terry Ruprecht
RV-9A Tip-up; IO-320 D2A
S. James cowl/plenum
(Dues paid thru Nov '18)
