Old 10-11-2013, 09:32 PM
AK-Models AK-Models is offline
Default Engine or avionics?
What would you buy first, assuming you can not get both at same time.
IO-360 with FWF and work on it.
OR
Glass cockpit and all that is coming with it and work on it.
Any input is appreciated.
RV-7A Standard kit
Empenage - Finished
Wings - Finished
Fuselage - almost done
Panel and engine done.
On to fiberglass.
VAF Donation 2020
Old 10-11-2013, 09:38 PM
PCHunt PCHunt is offline
I'm betting that the forum opinion will be unanimous that you do the engine first and wait until the last minute to buy avionics.
Just a hunch.
Engine technology is proceeding at a glacial pace. Avionics technology is changing daily.
Pete Hunt, [San Diego] VAF #1069
RV-6, RV-6A, T-6G
ATP, CFII, A&P
2020 Donation+, Gladly Sent
Old 10-11-2013, 09:41 PM
Bevan Bevan is offline
Don't know about others but GRT sells the EFIS boxes with no guts inside(mine was $100 refundable) so you can fab/fit the instrument panel and make up all your harnesses ahead of time. This will save you from putting out $$$ for the EFIS until you need it, and the prices come down and/or features go up as you work on other parts of the plane.
Bevan
RV7A Flying since 2015
O-360-A1F6 (parallel valve) 180HP
Dual P-mags
Precision F.I. with AP purge valve
Vinyl Wrapped Exterior
Grand Rapids EFIS
Located in western Canada
Old 10-11-2013, 09:59 PM
N9331v's Avatar
N9331v N9331v is offline
I'm at the same crossroad. I decided to do the engine, which I'm currently searching for.
Ed Martin
Bluskydtl
RV7
DKB
Donations 1/19 & 6/19
Old 10-11-2013, 10:55 PM
rhill rhill is offline
Default Engine
You will need to know what engine to order the right finish kit,avionics are outdated as soon as you buy them.
RHill
Old 10-11-2013, 11:31 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Yep, that is my vote.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 10-12-2013, 12:27 AM
MauiLvrs's Avatar
MauiLvrs MauiLvrs is offline
Engine ....
Dave & Trina
RV-9A Flying - 330 Hrs. Painted Finishing the interior.
Old 10-12-2013, 07:26 AM
Default Sounds like ENGINE it is...
Makes total sense with avionics getting up-dated very fast.
Thanks guys!
RV-7A Standard kit
Empenage - Finished
Wings - Finished
On to fiberglass.
VAF Donation 2020
Old 10-12-2013, 08:07 AM
BillL BillL is offline
Good choice ('cause I agree ) and you will need a lot of planning time for panel (and supporting hardware) locations, switches, and wiring runs all at the same time. Suggest you get installation dimensions and make some blocks for all the pieces to think through the process. Unless you have a solid modeler to make a complete design of the panel and forward fuse, that would be best.
This way, if you go to others for the panel assembly, you can specify wiring run lengths and split-offs from the main harness on the panel. I have spent unbelievable time in just thinking through making the wiring from my Stein build panel, making it neat.
Happy Building!
Bill
RV-7
Lord Kelvin:
Old 10-12-2013, 08:54 AM
craigvince's Avatar
craigvince craigvince is offline
I always advise my customers to not buy their avionics until everything else possible is done. Obviously there's some advanced planning required when it comes to cutting your panel, but the longer you can wait, the better. Avionics change so often, you never know what might be available when you're ready.
