Old 10-08-2013, 01:31 PM
swisseagle's Avatar
swisseagle swisseagle is offline
Default Louvers needed or not?
Hello,
I'm in the proces of installing the cowling. Now the question pops up, if louvers are needed or not?
I live in switzerland, so in the winter it is cold, in summer it can go up to 85-100? fahrenheit.
It is a RV-7A with IO-320
For sure it will be easy to do it now, before painting. But I only will do it when it looks neccesary.
Thanks for any input!
Dominik
RV-7A, TMX-IO-320, FM-150, Sensenich FP
Flying since 28. April 2016
Old 10-08-2013, 01:46 PM
Ron Lee's Avatar
Ron Lee Ron Lee is offline
You won't know until you fly.
Old 10-08-2013, 01:53 PM
eddieseve eddieseve is offline
Hi Dominik
I live in Sydney Australia and have an IO-360 in my RV7, I have difficulty getting the oil temperatures high enough in winter (it does not get cold here so to speak) and have blocked off 3/4 of my oil cooler, which is mounted on the rear of the plenum.
It is spring here at the moment, temps around 27C and I still have my oil cooler blocked off and temps are just getting into the 170F range.
So I would hold off on the louvers.
Cheers
Eddie Seve
Sydney Australia
First Flight 16th July 2012
RV-7 Phase 2, 30 Oct 2012
1100 hrs Feb 2020
Old 10-08-2013, 02:16 PM
ChiefPilot's Avatar
ChiefPilot ChiefPilot is offline
I live in Minnesota USA, which has a similar temperature range. I found that if anything, I have too much cooling for my IO-360. I was very careful to fit the baffles tightly, and to seal gaps with high-temp RTV to prevent air from leaking around the baffles instead of going through either the cylinder cooling fins or the oil cooler.
I'd be surprised if you need louvers; I'd build it and test fly first. If you have cooling issues, louvers are easy to add afterwards.
Brad Benson, Maplewood MN.
RV-6A N164BL, Flying since Nov 2012!
If you're not making mistakes, you're probably not making anything
Old 10-08-2013, 03:48 PM
swisseagle's Avatar
Default Oil cooler shutter
Hello Eddi and others
Thanks so far for this information!
This bring me to the point, that I testfly first and if neccecary install them later.
To bring oiltemps up, I install a Oil Cooler Shutter from Vans.
http://vansaircraft.com/cgi-bin/stor...ct=oil_shutter
and hope I can controll the temp as needet.
Dominik
Old 10-08-2013, 03:54 PM
Scremm's Avatar
Scremm Scremm is offline
I live in Maine with similar weather. RV8A with o-360-A1A and the oil cooler shutter works well to fine tune cooling in winter and summer. No louvers.
Claudio Scremin
N221Z RV8A Maine 600+ hrs
Old 10-08-2013, 04:05 PM
penguin penguin is offline
Hi Dominik,
I have a 6A with an O-320 and suffered from high CHTs until I added louvres. I believe the outlet hole is too small, so there is not sufficient airflow through the cowling. The louvres dropped my CHTs by at least 40F, so much so that for this winter I think I will block half off with speed tape. The oil temperature also came down slightly, but has never really been an issue.
My view is that, yes, louvres are required, especially for a nose dragger.
Pete
Old 10-08-2013, 05:30 PM
LifeofReiley's Avatar
LifeofReiley LifeofReiley is offline
If you need to add louvers, you have another issue.
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
Old 10-08-2013, 08:02 PM
rzbill's Avatar
rzbill rzbill is offline
You need the oil cooler louvers (or something else to simulate it such as a removable plate or aluminum tape)
Oil cooler louver kit from Vans
You do not need the cowl louvers like shown in the picture below
Bill Pendergrass
ME/AE '82
Old 10-08-2013, 08:19 PM
I have a 160 HP 0-320 (carbureted). I don't think you'll need louvers unless something is way out of sorts elsewhere.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
