Old 10-07-2013, 08:36 PM
celstar's Avatar
celstar celstar is offline
Default RV-4 rear seat flap actuating holes
Who has covered the flap actuating holes in the rear seat passenger area of a RV-4 and what have you used to cover them?
David Herrmann
RV-7 N174DH built and sold
RV-8A N369DP purchased and flying/ Sold
RV-8 N3170L purchased and flying/ Sold
RV-3B N313RV purchased and flying Sold
RV-4 N488TW Flying Sold
1946 J3Cub all stock and original flying Sold
1943 Meyers OTW-160 sold
1997 RV-4.5 N221TM wow, sold ��
Old 10-08-2013, 07:54 AM
fixnflyguy fixnflyguy is offline
Default What I did
I dont have a handy picture, but I made side panels from .020" aluminum that also double as arm rests. Some simple attach angles at the bottom for retainer screws, and I have angles riveted through the skin at the top, which could probably be eliminated if you were installing in a flying aircraft. I have gotten many compliments of the finished look, and no open flap mechanism, ect...send me a PM with E-mail, and I will snap some pics for you.
Bill E.
RV-4/N76WE
8A7 / Advance NC
Old 10-08-2013, 08:14 AM
Master Designs's Avatar
Master Designs Master Designs is offline
I'd love to see the photos as well if you get time to snap a couple. I'd post them for you here if you'd like.
Robert Kramar
Gilbert, Arizona
  • Vans RV-6A
  • Bell 47 D-1 H-13 Sioux Army/Mash Helicopter - Fully Restored and Flying!
  • Vans RV-4 (being upgraded to new panel, firewall, weldments and long gear legs)
Yearly VAF dues paid to date.
Old 10-08-2013, 09:20 AM
131RB 131RB is offline
I don't seem to be able to find a picture. Think of a 90 degree stick boot made of leather. 4 points attach to the floor in a rectangular pattern with the open end pointed fwd and wrapping around the flap actuating arm. Makes for a very clean install without losing any sidewall room.
Ryan
Old 10-08-2013, 10:26 AM
vfrazier's Avatar
vfrazier vfrazier is offline
Here is how I covered the flap pushrod holes, 10 years ago, to seal against drafts and dirt:
Here is a nifty flap pushrod gap seal that is easily made from the foam of a foam paintbrush. It really does a nice job, is cheap, and durable. It still looks fine after 10 years of service!
The paintbrush foam is soft, yet tough, and conforms nicely around the flap pushrod. The U-shaped piece of aluminum on the bottom was intentionally left rough, not deburred, and drilled full of rough holes so it would grip the foam tightly. That foam is just the ticket.
In the lower right corner you can see a hole which I melted through the foam with a soldering iron. When you install the floorboard, a screw goes through that hole. The foam scrunches down nearly flat, as you can see, and does not cause any fitting problems even though it is between the floorboard and angle on the fuselage.
Vince Frazier
www.f1aircraft.com
F1 Rocket and F4 Raider components
1-888-F1AIRCRAFT (1-888-312-4727)
www.flyboyaccessories.com
RV and Rocket Accessories, Tailwheels, Tools, & More
1-888-8FLYBOY (1-888-835-9269)
F4 Raider - under construction
F1-H Rocket "Crazy Horse" - sold
RV-4 "Chief Pontiac" - sold in 1994, purchased in 2018
