We've now done it correctly:
All four nuts have a flat washer against the engine-casing, then a new starwasher and then the nut. And this time, we made sure we placed the nuts the correct way.
Finally they all where torqued to spec.
A very tight thing, this whole operation, but it was doable.
BTW: the yellow torque-seal is only there as a reminder to self: that the marked nuts are torqued.
I don't use, nor prefer to use the torque-seal as a proof that the marked nut or bolt has become loose. The reason for this, is that I've seen several times that a nut or bolt has become loose with the torque seal intact.
Therefore, I put straight lines on nuts or bolts onto casings etc with a thick markerpen. Those lines will always tell the true story...
(the mentioned lines are not yet drawn on these nuts though)
Thanks for the help guys!
