Closed Thread
  #11
Old 10-01-2013, 07:26 PM
Sam Buchanan's Avatar
been here awhile
Pole vaulted may be a more appropriate statement.
Sorry for probably crossing the line (and this will probably get deleted by a moderator) but advertiser or not, this sounds far to much like scare tactic marketing to me.
The accident in Canada is well investigated and documented. The cause had nothing to do with the reinforcement part being promoted here.
The most recent accident is in early stages of an investigation. Making an assumption that this part would/might have prevented it is totally out of line.
Not only does this moderator not have any intention of deleting Scott's post, I totally agree with it.
I suspect nearly any part of the airframe can be damaged if not constructed properly/carefully as noted in several threads recently. This does not constitute a design flaw, however.
Sam Buchanan
RV-6
Fokker D.VII replica
  #12
Old 10-01-2013, 07:32 PM
Thermos's Avatar
Thermos Thermos is offline
Hopefully not, it needed to be said.
I think Allan has some great ideas, but I'd be really cautious about reinforcing a piece of primary structure without any analysis of why the part is cracking in the first place. Making a piece of structure stiffer than it was originally designed might fix one problem - if it even exists - but could cause problems elsewhere.
Dave Setser
RV-7 N701ED FLYING!
Nashua, NH (KASH)
  #13
Old 10-01-2013, 07:56 PM
aerhed aerhed is offline
Alan is telling us about "emails" reporting cracks. Seems this forum would have been all over it. Maybe the moderators have a cover up going. We'll call it "Tailgate".
Actual repeat offender.
  #14
Old 10-01-2013, 07:58 PM
LifeofReiley's Avatar
LifeofReiley LifeofReiley is offline
Now that was TOO Funny! Wonder how many of the tail cracked airplanes are Sliders vs Tip-up? Hang in there Alan.
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
  #15
Old 10-01-2013, 08:00 PM
ChiefPilot's Avatar
ChiefPilot ChiefPilot is offline
Caution: Conclusions being jumped.
Agreed. Still, you have to admit it's a fun game.
Brad Benson, Maplewood MN.
RV-6A N164BL, Flying since Nov 2012!
If you're not making mistakes, you're probably not making anything
  #16
Old 10-01-2013, 08:40 PM
gtmule gtmule is offline
concur....
And the engineer in me has to state (as someone else already has) that slapping a doubler on something isn't always productive....
Macon, GA (KMCN)
RV-7, Niner Fife Victor
  #17
Old 10-01-2013, 09:03 PM
Even so, a jam nut wrench that works with a torque wrench and the rod end would be a useful thing.
Dave
  #18
Old 10-01-2013, 09:17 PM
Norman CYYJ Norman CYYJ is offline
In the next few years as more and more of Vans aircraft get airborne there will be more and more areas that fail for some reason or another. If we get hyper paranoid over all of these failures and beef them up with dubious parts the plane will be so heavy that it will never leave the ground thus solving all inflight failures. I believe that if the plane is built to Vans specifications and has suffered no damage on the ground or inflight by over stressing these planes are well designed and safe as they are.
  #19
Old 10-01-2013, 09:26 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
If you go to the video on the Anti Splat site where he talks about the stab mount reinforcement plates, at the three minute to three and-a-half minute area there are photos of a couple parts that have cracked in use. These photos were taken from threads here at VAF.
http://antisplataero.com/Videos.html The video is the second one in line.
Also, here is an old thread to look at. http://www.vansairforce.com/communit...ighlight=crack
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
  #20
Old 10-01-2013, 10:09 PM
rv6ejguy's Avatar
rv6ejguy rv6ejguy is offline
From the Canadian accident, we can take lessons about observing Vne, Va, balancing of control surfaces and finally that rolling G limits can be substantially lower than straight pulls on some aircraft.
I doubt if there is a systemic problem with RV tails when being flown within the defined envelope and being properly constructed or there would be a lot more failures. Many RVs are flown pretty hard.
Beating on an airplane continuously near, at or over the limits certainly hastens fatigue which is why aircraft used regularly for aerobatics are inspected (or should be) more frequently and in a more detailed way (ask Sean Tucker).
This is just food for thought.
We should wait for the full conclusions of the investigation. In the meantime, it does no harm for anyone concerned to thoroughly inspect these areas.
Turbo Subaru EJ22, SDS EFI, Marcotte M-300, IVO, Shorai- RV6A C-GVZX flying from CYBW since 2003- 441.0 hrs. on the Hobbs,
RV10 95% built- Sold 2016
http://sdsefi.com/cpi2.htm
Closed Thread
