Old 09-19-2013, 12:39 AM
Clouddancer Clouddancer is offline
Hello Jorge,
The reason for the transverse orientation was probably the same instruction that you have read. As I'm currently on vacation, I do not have everything on hand. But I believe, it was written in the Ellison manual. As the two units are technically very similar, this should apply as well to the Rotec TBI. But I had no reports from anyone that has tested both orientations.
On the other hand, the transverse mounting made the installation possible without adding bellcranks.
Our RV is still under construction, so I can not provide any real experiences, sorry.
Yes, you will find the remark on the installation orientation under the following link to the Ellison website:
http://ellison-fluid-systems.com/app-orientation.shtml
Andreas Uebersax
RV-4 SN2416 in slow progress
Switzerland
VAF donation 2019/12/13
Last edited by Clouddancer : 09-23-2013 at 06:23 AM. Reason: Spelling & added link
Old 09-23-2013, 06:30 AM
Default Air sense tube nipple orientation
Dave
Thanks a lot for the information on the orientation of the air sense tube! Your reasoning seems logical. I suppose that I can rotate the backplate of the regulator. I will check that with Rotec.
Do you know the reason for the leaking diaphragme on the Rotec and/or the Ellison unit?
Thanks, Andreas
Andreas Uebersax
Switzerland
Old 09-23-2013, 11:29 AM
pitts flyer's Avatar
pitts flyer pitts flyer is offline
Below is the essence of our exchange about the leaky regulator diaphram. I am getting a replacement diaphram (and paying the postage to do so). I had purchased another Rotec for my RV-4 project, so I had a spare regulator on hand, and have just installed it in the mean time. Pitts ran good again. Bottom line is I like the product when it works--when it works, it works well, but I have had some issues, and I don't care much for their customer service--the postage requirement and timeliness. YMMV......
Regarding the Ellison I had a about 8 years ago, at the time I didn't know what the problem was, only the symtoms, so I sent it to Ellison as they requested, and they fixed it right away. They said water had gotten into the diaphram area--nobody knows how. I think it was a leaky diaphram and it was fuel, but they fixed it and sent it back with no charge, and quite prompt service too as I recall.
My e-mail exchange with Rotec below:
Mon 9/16/2013 6:54 PM
Hi David,
It will take you 5mins to give that centre rivet a few extra taps and peen it over a little more. Then the issue will be solved. A much easier path.
But If you would like us to send you out a new diaphragm we will under warranty but the old diaphragm will need to be sent back. Shipping of the new parts is not covered under warranty and will need to be paid by yourself.
Kindest regards,
Paul Chernikeeff
Technical Director
Sent: Tuesday, 17 September 2013 7:47 AM
To: 'Paul Chernikeeff'; RotecAdmin@bigpond.com
Subject: RE: Fuel in sense tube
Paul,
I have given this a lot of thought. I don’t believe that I should have to repair a defect in manufacturing such as this is, or have to make the tools to do it—or pay someone to do it for me. I think you should send me a diaphragm that is correctly assembled/made. There is a chance that I will mess up the fix or it won’t work for some reason or another—and as a customer, I don’t think I should have to make this type of a fix. Therefore I am requesting that you send to me a non-defective diaphragm, and I will install it.
By the way, this is the second defect that this TBI has had. The first was the idle circuit was not made properly and I had to send it back to you (and pay all the postage too). It now only has 30 hours on it, and another defect.
Thank you,
David Magaw
Sacramento, CA USA
From: Paul Chernikeeff [mailtoaul@rotecaerosport.com]
Sent: Tuesday, September 10, 2013 1:47 AM
To: 'Dave Magaw'; RotecAdmin@bigpond.com
HI Dave,
I have seen this before, its an assemble error. What is happening is the rivet that hold the support plate to the rubber diaphragm is not firm enough. The rivet need to be peened just a little more then the leak will stop, Its an easy fix.
Use compressed air to pop the top of the regulator off. Don’t pry the lid off, you will damage the surfaces and risk puncturing the diaphragm.
See attached how to peen the centre rivet more. You will need to drill a small hole is a peace of stock to support the small pip on the back side, see attached. [there were pictures attached to this e-mail showing what he described]
Kindest regards,
Paul Chernikeeff
Technical Director
Date: Fri, Aug 30, 2013 at 6:35 PM
Subject: Fuel in sense tube
To: rotecengineering@bigpond.com
I have been noticing that I am getting fuel in the sense tube--in the yellow tube between the TBI (see installation picture attached) and the regulator. Also, the other day, the engine would not run right at full throttle (like for take-off), and sputtered at full throttle such that I aborted a take-off. It did the same when I tried full throttle again with static run-ups. When I pulled the tube off of the regulator, it drained some fuel, and when I pushed the button on the regulator, more fuel came out of the regulator. After draining this fuel, I was then able to make a flight with no problems on takeoff or in the flight, but more fuel was in the tube after that approximately 20 minute flight. I think that there is not supposed to be fuel in this tube or that side of the regulator. How is fuel getting in there and is this normal??
Dave Magaw
Pitts N55DP
Sacramento, CA, USA
Dave M
RV-4 finished, awaiting AW certificate
Old 03-29-2014, 02:37 AM
TIPSYNIPPER TIPSYNIPPER is offline
Default Progress please?
Hi Guys,
Thank you for those posting on this subject.
I have just bought an RV4 (O320 160hp) which I want to fit inverted systems to. Some Q's please?
1. Any further comment on carb' orientation (across or fwd/aft)?
2. Service difficulties/problems?
3. Suggestions?
4. Ellison or Rotec?
5. Mogas or Avgas?
Thanks in advance.
Neil
Old 03-29-2014, 02:08 PM
RV4UK RV4UK is offline
Hi Neil,
I'll be interested to hear what happens if you go down the Rotec TBI route.
I have purchased a partially completed RV-4 kit in the States and will be shipping it to the UK next month. I have also purchased a Rotec TBI although I am at least a couple of years away from fitting it.
Regards,
Simon
Old 03-30-2014, 07:38 AM
Vansrv7arob Vansrv7arob is offline
Originally Posted by TIPSYNIPPER View Post
Hi Guys,
EAST/WEST RECOMMENDED
PAUL AT ROTEC IS A GREAT GUY, UNFORTUNATELY NOT EVERYTHING IS MADE IN USA SO INTERNATIONAL POSTAGE/TIME ZONES IS A FACTOR TO CONSIDER, BUT HOW MANY RVS HAVE GOT ANDAIR FUEL VALVES MADE IN THE UK? Same issues here.
3. Suggestions?
Its a proven design. There is fabrication involved for hookups, spacer block and to mount pressure regulator, so this isnt for everyone.
Check $$$ on Ellison, you mightn't be too far off getting a mechanical FI system fitted, but when you add expensive HP fuel pumps (mech and elec boost) you'll see just how attractive TBI is.
5. Mogas or Avgas?
I believe compatable with both. Im planning on compatabilty to run mogas.
Thanks in advance.
Neil
I've collected a heap on info on the Rotec send me a PM and i can email what i have through to you.
Regards,
Rob.
................__|__
......______(-o-)______
M: (61) 401 578 700
Old 05-24-2014, 05:05 AM
Hi Guys,
I have a Rotec on order for my RV4, how are you guys getting on please?
Best wishes,
Neil
Old 05-24-2014, 11:12 AM
Hi Neil,
My Rotec TBI should be arriving sometime in the next couple of weeks along with my aeroplane and engine.
I am some way off fitting it to the aircraft as there is quite a bit of aeroplane to complete first. However it might be worth collaborating when it comes to putting a mod through the LAA.
Simon
Old 05-24-2014, 12:19 PM
Nate-ISU Nate-ISU is offline
Just a reminder to all that Ellison does not recommend running Mogas with their TBI. Not sure what Rotec has to say.
Old 05-24-2014, 03:00 PM
Tony Spicer Tony Spicer is offline
Rotec sez:
The Rotec TBI Fuel System can run on both aviation gasoline (Avgas) and automotive gasoline (Mogas). However it should be noted that vapor lock is far more prevalent with auto fuels compared to Avgas.
And for what it's worth, Ellison no longer manufactures TB's.
Tony
