Go Back   VAF Forums > Avionics / Interiors / Fiberglass > Interiors
Old 09-21-2013, 07:13 AM
paul330 paul330 is offline
Default Contact Adhesive Removal
I have been fitting the headliner and got a little enthusiastic with the spray glue and it has seeped through the fabric in a couple of places.
What's the best way to remove contact adhesive without destroying the fabric or taking the colour out?
Paul
Mercy Air, White River FAWV
RV-10 ZU-IIZ - "Zeus"
2019 Donation Made
Old 09-21-2013, 07:30 AM
TX7A TX7A is offline
That will be a tough one, Paul. Maybe start with some mineral spirits or naphtha. Here in the States, we have a couple of products, Goo-gone & Goof-off, that may work. I would certainly do a test before using anything.
Sam Evans
RV7-A O-360 C/S
VAF#812
Old 09-21-2013, 10:40 AM
az_gila's Avatar
az_gila az_gila is offline
This stuff from Spruce works well. I've only used it on hard surfaces but the description says it works on fabrics.
https://www.aircraftspruce.com/pages...adhesremov.php
It's citrus based and doesn't smell nasty...
A good car supply place/coachbuilders (US = upholstery shop) might also stock it.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 09-21-2013, 10:54 AM
Thanks guys.
I've found a grease/paint/glue stain remover (naphtha based). I'll try that on some scrap and see how it goes.
Paul
2019 Donation Made
Old 08-13-2014, 09:06 AM
Pittsartist Pittsartist is offline
Originally Posted by paul330 View Post
Thanks guys.
I've had some good results from just dabbing "gaffa" tape on for a second and pulling straight off (a bit like hair waxing !)
obviously something to try with care - but the advantage is no solvents / residues or abrasion marks.
Old 08-13-2014, 06:09 PM
Norman CYYJ Norman CYYJ is offline
Not sure on the hair waxing but MEK will do the job.
Old 08-13-2014, 08:25 PM
aerhed aerhed is offline
Tough one. Try a quick dry electronic cleaner aerosol. Spray through the front to attempt blowing the glue back. What kind of fabric?
Actual repeat offender.
