09-11-2013, 05:57 PM
Prop balancing in Michigan?
I've been searching for someone who does dynamic prop balancing in west Michigan and have come up empty! I have a 200RV and am supposed to get this done. Help!
Paul K
West Michigan
2020 donation made, exempt but worth every dime!
09-11-2013, 06:05 PM
I'll be bringing my balancing equipment to LOE, maybe you should stop by
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
09-11-2013, 06:22 PM
Thanks Walt but have family in town that week and geeze, that's a long way to go for a balance job! I'm sure it would be the best but still.....
Paul K
West Michigan
09-11-2013, 06:42 PM
prop balance
If you would like to fly down to Indy KMQJ I can balance this for you. just give me a call 317-201-8517. Thanks!
Jon Hubbell
RV-6 Flying IO-320X tip up 500+hrs G3X 2004 Oshkosh Outstanding workmanship award, 2004 Sun N Fun Best Workmanship 2006 Sun N Fun Outstanding Aircraft
RV-10 Flying IO-540-C4B5X 500+hrs G3X 2011 Bronze Lindy Award Winner
"Negative Ghostrider the pattern is full"
09-11-2013, 07:18 PM
Closer than colorado but still! Got to be someone closer yet.
Paul K
West Michigan
09-11-2013, 07:34 PM
Seeley aviation at KHYX in saginaw does prop balancing
RV-8
flying
09-11-2013, 07:45 PM
I live in Midland, MI and know a few local RV builders. I will ask around to see if they had the balancing done locally.
Ken Stockman
Midland, MI
EAA Chapter 1093 member
FaceBook Page: Ken's RV-14
RV-14a (serial number 140073)
N73XP
Plane at hangar and the wings ON.
09-12-2013, 06:26 AM
Paul,
Terry Brokaw lives near Three Rivers can do it. He can also bring his equipment to you. He's a long time AP/IA, Tech Advisor and built a Long Ez. Contact him at 734-730-3254.
Jim Butcher
09-12-2013, 03:55 PM
Hi Walt-
I know you have a great reputation for prop balancing. For those of us who can't make it to you, do you have any suggestions about what questions we should ask of other prop balancers in order to be most likely to get the best results (e.g. what types of equipment or process we should inquire about)? I'm right now getting my prop repitched by Craig Catto and balancing is one of the first items on my list once I get it back.
Thanks.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
09-12-2013, 05:30 PM
Originally Posted by alpinelakespilot2000
Hi Walt-
Thanks.
I would ask things like:
What type of equipment do you use? (MicroVib, ACES, Chadwick are the best)
What vibration level do you typically get after balance? (I guarantee .05 IPS or less)
Where do you place the weights? (on RV's with Lycs the normal spot is the flywheel so you don't have to drill any holes)
Do you do a spectrum analysis?
What type of documentation is provided?
Is the work done by a certified mechanic?
