Old 09-04-2013, 09:11 PM
dspender dspender is offline
Default tank sealant
I placed the trailing edge and foam ribs in the trailing edge of my elevators. I clecoed an angle iron of aluminum to the trailing edge to keep it straight as I let the tank sealant set. Will I have difficulty removing the angle iron of aluminum from the elevator skin after things set for a few days. I did not placed any type of tape or wax on the angle iron before placing it in contact with the skin and tank sealant.
Dennis
Old 09-04-2013, 09:16 PM
rene@felker.com's Avatar
rene@felker.com rene@felker.com is offline
I did not have any problems....
Rene' Felker
N423CF RV-10 Flying
Old 09-04-2013, 09:54 PM
Ron B. Ron B. is offline
I never had any problem either. I still LOL when I hear so many people call "alum. angle" , angle iron of alum. We are so use to calling that shape angle Iron rather than just angle.
Thanks Ron
RV-10 SOLD
RV-14 Flying
AirCam flying
Old 09-04-2013, 10:03 PM
Bevan Bevan is offline
Originally Posted by dspender View Post
I placed the trailing edge and foam ribs in the trailing edge of my elevators. ...
What are the "foam" ribs you're referring to?
Bevan
RV7A Flying since 2015
O-360-A1F6 (parallel valve) 180HP
Dual P-mags
Precision F.I. with AP purge valve
Vinyl Wrapped Exterior
Grand Rapids EFIS
Located in western Canada
Old 09-05-2013, 08:52 AM
ppilotmike's Avatar
Default Vasoline
Dennis, you probably will be okay, but may have to due some slicing to get it off the angle when completely cured. The proseal is tough stuff. I don't remember the original thread, but another builder suggested smearing a very thin layer of vasoline on the angle prior to clecoing (and proseal spooging out). It works perfectly, and you really don't need to use much.
Mike Rettig
VAF Dues Current
Old 09-05-2013, 10:08 AM
Randle Randle is offline
If you can pry the "angle iron of alum" (couldnt resist) up just a little bit, pour some MEK in there and let it set for about 10 minutes, then try and pry it up.
If you are 90% efficient, and your buddy who checks the 10% you missed is also 90% efficient, together you're 99% efficient.
RV-7A - empennage done minus glass
wings nearing completion
Old 09-06-2013, 02:10 PM
Well I got nervous the night I secured the trailing edge with the angle of aluminum and couldn't wait for reassurance. So I got out of bed and removed the clecos and the angle of aluminum and reclecoed the trailing edge. I then fell fast asleep. Everything is straight so far. Now I will work not to mess it up as I begin to rivet the edge.
Dennis
Old 09-06-2013, 02:11 PM
Bevan
The 10 plans call for foam ribs to support the upper and lower skins of the trailing edge of the elevator, the edge outboard of the elevator trim panel.
Dennis
