  #11
Old 09-04-2013, 06:51 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Sounds like a lot of you need to chase down some air leaks.
Or put a valve on the tank outlet.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 09-04-2013, 09:24 PM
flyboy1963's Avatar
Default and another thing....
One timer for the compressor, and another one that beeps, weekly or otherwise...... & states
" buy flower/chocolates for the long-suffering spouse"
and/or
"take her to a nice restaurant". wear a tie.
etc.
Perry Y.
RV-9a - SOLD!....
Lake Country, BC
Old 09-04-2013, 09:29 PM
LAMPSguy's Avatar
LAMPSguy LAMPSguy is offline
Default a bit anal retentive
My way is a bit better for the tank...turn off and release the air every day. Allow it to drain condensate and leave the drain open. Your tank will last a lot longer. If you live in high humidity area and "never" drain it, you will see cycle times rise. Then you wonder why its running 100%...the water will collect and effectively reduce the tank capacity.
RV-? in planning stages.
RV-14 #140050 SOLD
Permanently willing to contribute fuel for RV rides
Helicopter ATP/CFI(I)
ASEL/AMEL Commercial/Inst/CFI(I)
Aerobatic Instruction available
Atlanta based.
Old 09-04-2013, 10:17 PM
Paris Paris is offline
Originally Posted by krwalsh View Post
Why not just put it on a timer that turns on in the morning and off at night? Anything you can possibly do to keep the SO happy is a good thing...
Most timers you'll find won't handle the load unless you have a very small compressor, however you can find higher capacity models if you look hard enough. I have one that will handle 15 amps.
Old 09-04-2013, 10:23 PM
That's the way I run my compressor, but I know people who never seem to drain their tank. If you have a cheap compressor the moving parts will probably wear out before the tank rusts through, but I bought one that I hope will last for many years and I do all that I can to make sure it does.
Old 09-05-2013, 05:57 AM
fehdxl fehdxl is offline
The real danger of leaving the compressor on unattended is a ruptured hose, then the subsequent 100% duty-cycle and fire. Yes, the likelihood is low, but the risk very high...why chance it? Be safe, Jim
Old 09-05-2013, 06:26 AM
Larco's Avatar
Larco Larco is offline
Get a belt driven compressor. Much quieter and easier on everyone's ears. Larry
Old 09-05-2013, 07:09 AM
gvouga's Avatar
gvouga gvouga is offline
Just wait until you come in and sit down on her new couch with Proseal on your pants.
Greg
RV-7
Old 09-05-2013, 07:37 AM
brianwallis's Avatar
brianwallis brianwallis is offline
VAF moderator
Default doghouse
That's why you build a nice doghouse.....
and then rent it out to help pay for diapers.... anybody need space? 62GA, make offer for monthly rent to flying or project RV. 3k long grass North/South
Brian Wallis
(Exempt AND VAF dues paid 02 FEB 16)
Callsign: VOODOO sold RV3 to pay for ratings !!!
AP/IA COM/Multi/IFR/350 type
Old 09-05-2013, 09:35 AM
swixtt swixtt is offline
you didn't!
RV9.... Tail done. Inspection done! Wings pre-cover MDRA inspection done. Closing them up now. Fuse underway.
