Old 09-02-2013, 09:00 AM
java's Avatar
java java is offline
Lots of good suggestions. In response to some of them...
I mentioned I didn't want to run the 30 pin connector through apples adapter. I guess I was thinking I'm fine with the small dongle hanging off the iPad, but through the adapter it would get to be somewhat less than small and risk getting caught on things. Plus, I know that their new lightening connector dongle can have power plugged into it, so that the ipad is charging while in use. I have a cigar lighter positioned well for this (and hence, why I'm not concerned about the dongle drawing ipad power). Not sure, but I don't think I can have the ipad on ships power running the 30 pin through an adapter.
I also mentioned I didn't want the bluetooth version. If I have the ipad mounted in the cockpit with power through the dongle, I never have to worry about batteries. If I have a bluetooth receiver, I need to worry about making sure I turn it off, and even if it lasts 14 hours the batteries will die sooner or later. Apart from the 50% cost premium, I just don't want to have to worry about batteries.
That all said, I'm taking to heart some of your points about the bluetooth working so well, and the dongle sometimes not.
Decisions, decisions...
JV
Calgary, Alberta, Canada
RV7 QB - Airframe largely complete, sans canopy and glass... unfortunately sold
RV6 - O-360-A1A, Hartzell CS, dual G3X VFR... purchased
Dues paid 2015
"Being defeated is only a temporary condition; giving up is what makes it permanent."
-- Marilyn vos Savant
Old 09-02-2013, 10:41 AM
Kevin Horton's Avatar
Kevin Horton Kevin Horton is offline
The Bad Elf Pro Bluetooth GPS can be charged in flight using a USB cable, just as your iPad can be. So, if you have cockpit power available, you don't have to worry about the Bluetooth GPS battery running low any more than you need to worry about the iPad battery running low.
Kevin Horton
RV-8
Moses Lake, WA, USA
http://www.kilohotel.com/rv8/
Old 09-02-2013, 12:27 PM
DCat22's Avatar
DCat22 DCat22 is offline
I know several people who do track auto racing/training with the Bad Elf Pro...and I've heard good things from that group.
-Rick Greer, VAF #2492
Old 09-02-2013, 04:05 PM
n82rb's Avatar
n82rb n82rb is offline
i use the bad elf pro also. I love it because not only can I use it for flying I use it with my jet ski. I just turn on the data logger and throw it in the storage area. the battery life is never a question. when i get home i can down load it to the ipad. I also use it on my bike rides, and hikes.
bob burns
rv-4 N82RB
