Acuracy?
What kind of sensors are you using? Here's been my experience on the same airplane (RV10 with AFP injection):
VDO sender: reads 27 PSI
Stewart-Warner: reads 30 PSi
Kavlico: reads 22 PSI
All I did was change out senders and change the calibration table appropriate to the sender. I need to get an accurate direct-reading gauge and stick it on there. However, I noticed in some of Rob Hickman's pictures that his reads 22 PSI with the Kavlico sender as well, so I'm thinking it's OK.
Vic
 Vic Syracuse
www.Baselegaviation.com
