Old 08-18-2013, 09:11 AM
jay.pearlman jay.pearlman is offline
Default Screws for wingtips
I am mounting the wingtips. The plans say either screws (removable) or rivets. I need to make it removable because antennae and lights are mounted in the tip. The choice of screws seems to be 6-32 or 8-32. Which size screws have you used? Why the choice?
Old 08-18-2013, 09:16 AM
Fred.Stucklen's Avatar
Fred.Stucklen Fred.Stucklen is offline
I used 6-32 srews in the provided hole locations. My wingtips are also gas tanks (9.5 gals each). I've not seen any indications of tip movement.
Fred Stucklen
wstucklen1@cox.net
RV-7A N924RV Flying (1825 Hrs & counting)
RV-6A N926RV 875 Hrs (Sold)
RV-6A N925RV 2008 Hrs (Sold)
Old 08-18-2013, 09:21 AM
aerhed aerhed is offline
Eights are tough because they're so near the edge you get a wavy skin. Bigger heads are hard to get flush also. Some guys have used fours, but I hate fours because they strip or snap so easily. So.....sixes, I guess.
Actual repeat offender.
Old 08-18-2013, 10:23 AM
Stoo Stoo is offline
I used the Cleaveland kit with 4-40 screws.
http://www.cleavelandtool.com/Stainl...ctinfo/WHS220/
Stewart Willoughby
6, finishing
Old 08-18-2013, 10:34 AM
wjnmd wjnmd is offline
Default Cleaveland wingtip kit
I used the Cleaveland wingtip kit but I also used Click-Bond nutplates that are cemented to the wingtip with a two part epoxy. Easy to install and easy to remove if necessary.
Bill Near
RV-7A Flying
Old 08-18-2013, 11:02 AM
instructor_bill instructor_bill is offline
Stewart Willoughby
6, finishing
then also go to microfasteners.com and buy #4 torx screws and you have a really nice, low stripping solution.
I found that the screws that came with the cleveland tool kit stripped very easily. I tried everything including flattening the tip on a high quality new screw driver tip to get a deeper bite in the screw head-- still stripped.
torx is the way to go.
Bill Mason
RV7 SB in construction
Avionics, Wiring, FWF, interior, and paint to go.
Walt's Avatar
Walt Walt is offline
I agree, #6 are the best here.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 08-18-2013, 11:41 AM
RV7Guy's Avatar
RV7Guy RV7Guy is offline
Default Don't use 4-40's!!!
I would definitely not use 4-40's they are simply too small and the screw heads are easy to strip out. I did one wing tip with these and removed and replaced with 6-32. Better grip and MUCH cheaper. I can't recall any other 4-40's in the construction.
Regarding Torx, I don't get the fascination with them. You gain no advantage over Phillips. Now you have to carry a few extra Torx and the proper wrench.
Remember to use the back up metal strips when you attach the nut plates to the glass.
Darwin N. Barrie
Chandler AZ
www.JDair.com
RV-7 N717EE-Flying (Sold)
RV-7 N717AZ Flying, in paint
EMS Bell 407,
Eurocopter 350 A-Star Driver
Old 08-18-2013, 11:51 AM
Joe Joe is offline
Default 6-32 for me ...
I hate to sound like a clueless "me too-er" but I like many others, I used 6-32's.
It was easy to make the decision: weigh a bag of seventy-eight (!) 6-32 screws and nutplates and weigh a bag of 8-32s <g>.
I've had no issues with the smaller screw heads using proper techniques (Boelube on initial installation, good #2 Phillips bit).
Joe
Joe Dubner
RV-8A
Independence, OR
Old 08-18-2013, 12:38 PM
scard's Avatar
scard scard is offline
Our current airplane has 4-40 torx. I'm not going to do that again. Next one has 6-32 phillips.
Scott Card
CMW E-Lift
