Old 07-23-2012, 03:09 PM
hevansrv7a's Avatar
hevansrv7a hevansrv7a is offline
Exclamation My new prop from NZ
It can finally be made public.
I bought the first prop designed by John McGinnis (Synergy aircraft). It is being made by a new New Zealand company that can be found at:
www.kiwipropellers.com
It is designed for my 7A.
If you are here at OSH, the NZ compound is directly west of the Honda Jet tent a short ways north of show central. there are 3 prototypes there.
On the map as #406.
I am bringing the guys from the OSH NZ exhibit to the social at the beer tent tonight. Doug: come find us and they will probably buy an ad from you. Look for the white ball caps with green logo.
When I have flown the prop I will do my usual, honest, objective write-up
H. Evan's RV-7A N17HH 240+ hours
We can lift ourselves out of ignorance, we can find ourselves as creatures of excellence and intelligence and skill. We can be free! We can learn to fly!" -J.L. Seagull
Paid $25.00 "dues" net of PayPal cost for 2015, 2016, 2017 and 2018 (December).
This airplane is for sale: see website. my website
Old 07-24-2012, 05:17 PM
Dragonfly Dragonfly is offline
Very interested to hear how you get on. Good to see NZ products popping up on the aviation scene.
Old 08-03-2012, 09:32 AM
hevansrv7a's Avatar
Default Update
The prop is on its way back to Kiwi-land (New Zealand) for a couple of reasons:
1. It will probably be changed so that it can be installed on my RV without a new extension. It's an issue of part of the blades being aft of the base of the hub in the current version.
2. John, the Mitchells and I all agreed on a good ground-testing plan which will precede putting it on my airplane.
The prop was a big hit at the show and many people expressed interest in having one designed for their airplanes - some of which are not RV's. But that is O.T.
Here are some things that I learned about it:
  • constant Reynolds number
  • 25 custom NLF airfoils blended, all by Synergy designer John McGinnis
  • some L/D ratios on some of the airfoils that are so high I won't say them out loud, here.
  • lift distribution more parabolic than elliptical
  • makes good use of the "q" near the hub
  • twist is less than "normal" because the necessary advance ratio is accomplished with airfoil design.
  • The airfoils adapt in thickness, camber, and design Mach number as they move outward. Keeping the Reynolds number constant prevents unnoticed lift/drag changes as those factors are varied in pursuit of the desired lift distribution.
  • all composite construction - no wood
  • I have not seen it yet but there will be a custom spinner with it
And, yes, the Kiwi's have begun the process of becoming advertisers on this forum. I put them in touch with Doug even though we missed him at the beer tent (where I was told he was not present).
One more thing: a few people tried to compare it to a Paul Lipps prop. I mean no disrespect to the late Mr. Lipps, but, no, that's not even close.
Last edited by hevansrv7a : 08-03-2012 at 04:38 PM. Reason: added language to prop design features from the designer
Old 08-05-2012, 05:32 AM
sonex293 sonex293 is offline
Thanks for the update. Always curious about new propellers....
Michael
Old 08-17-2013, 09:53 PM
hohocc hohocc is offline
Just noticed the Kiwipropellors website has been suspended.
Does anybody have any more positive news about them?
Old 08-18-2013, 10:19 AM
hevansrv7a's Avatar
Default Kiwi Props
I have not given an update because I have not had anything concrete to say. However, the prop that John McGinnis designed has been redesigned and John tells me that there will be a production version but he did not say when.
The Kiwi folks may come back into it later, but I expect that the first production versions of John's new prop design will be produced in north America.
I still expect to put that prop on my 7A and see what it does. In the meantime I am refining some of my test techniques because I found some deficiencies in them. I will put out an article on that when I have completed the revision.
If things work as I expect, the revised testing and analysis stuff for my airplane will come first and then there will be a write-up on the new prop with the new techniques and analysis.
Sorry for the lack of really specific information. More to come.
