Closed Thread
  #71
Old 08-07-2013, 03:27 PM
sahrens's Avatar
sahrens sahrens is offline
Default MTBF
With any new development there is an unknown MTBF. If I lose a starter cont. I can probably find one anywhere I might fly. Any analysis on MTBF you can share?
Scott
RV-7 N818BG (flying)
Bearhawk Patrol (building)
  #72
Old 08-07-2013, 03:32 PM
Master Designs's Avatar
Master Designs Master Designs is offline
I am at the point of needing to order one or will have to buy new parts to wire the old fashion way as I'm changing out my battery, wiring (will be going VP-X) and switching steam gauges to a Dynon/AFS panel.....any idea on the ETA for sellable units?
Robert Kramar
Gilbert, Arizona
  • Vans RV-6A
  • Bell 47 D-1 H-13 Sioux Army/Mash Helicopter - Fully Restored and Flying!
  • Vans RV-4 (being upgraded to new panel, firewall, weldments and long gear legs)
Yearly VAF dues paid to date.
  #73
Old 08-07-2013, 03:44 PM
Low Pass's Avatar
Low Pass Low Pass is offline
Ditto. Can you provide reference links to info on the technology and reliability of the components?
  #74
Old 08-08-2013, 09:13 AM
MCA's Avatar
MCA MCA is offline
My experience is that FBOs may carry 24v parts but rarely 12v parts. So it'll likely take you as long to get a 12v starter as it will take us to ship you a replacement unit overnight.
No MTBF numbers yet, but it should be higher than the VP-X which is significantly higher than mechanical breakers.
Marc Ausman
RV-7 980 hours, IO-390, VP-X (sold)
RV-8 (flying a friend's)
Thinking about low and slow backcountry build.
VAF Advertiser - Aircraft Wiring Guide
Book to help with experimental aircraft wiring.
  #75
Old 08-08-2013, 10:51 AM
Buggsy2's Avatar
Buggsy2 Buggsy2 is offline
This brings up the larger issue when we build our experimental planes: stick with traditional equipment that may be easier to fix, or, modern equipment that must simply be replaced when it fails.
I and many others are going the latter route: glass panels, electronic ignition, and Vertical Power's electronic "buss". I thought about this some before that decision, and figured that overnight shipping of a failed part would be about as fast as trying to find a mechanic to fix a traditional piece of equipment. Further, with my mission as VFR, I could limp home with a failed glass panel, say, using an iPad as backup.
Ralph Finch
RV-9A QB-SA
Davis, CA
  #76
Old 08-08-2013, 12:31 PM
alcladrv alcladrv is offline
Just make sure you the FAA required instruments, like a compass, airspeed indicator and alitimeter or their equivalent, for VFR flight. I doubt that an iPad qualifies.
That's why I kept those instruments as backups in my panel even with a 2 screen G3X.
  #77
Old 08-08-2013, 12:59 PM
Ironflight's Avatar
VAF Moderator / Line Boy
But none of those is actually required for flight in an experimental - at least legally.
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
  #78
Old 08-08-2013, 02:03 PM
Low Pass's Avatar
He mentioned contactors. These are widely available from stores and other hangars on the road. (I carry a spare personally.) You have any links to the critical components (solid state relays?) you're proposing to use in your new device that set you apart from conventional? How do you manage the high current load of starting? Parallel devices? I'm all about moving into new technology when I can balance the risk, performance, convenience vs. available personal resources equation.
  #79
Old 08-08-2013, 02:04 PM
Buggsy2's Avatar
A while ago I asked about this in the Glass Cockpit forum of VAF: for VFR, if you had included round gages with your glass panel, would you do it again? If you had not, do you wish you had? Most responded to the effect they weren't useful. I'm going to leave space for 3 small gages, but not install them.
Ralph Finch
RV-9A QB-SA
Davis, CA
  #80
Old 08-08-2013, 03:06 PM
My own experience with user-replaceable/reparable components, compared to sealed, integrated devices is that when the new sealed can't-work-on-them stuff is available, it's often - not always - more reliable than what's been replaced.
In other words, you can't repair them but then again odds are you won't ever need to.
This experience has been more than balanced by quite a dismal experience set from being an early adopter of technology. I now prefer some service history before committing. And since I figure I'm a year or 18 months from that stage, I hope that y'all do a good rigorous job of wringing these things out for me. Kindly remember to report back and let us know.
Thanks much!
Dave
Dave
Closed Thread
