07-30-2013, 05:17 PM
CNG alternative? Dual-fueled Husky to be at AirVenture
http://www.aviataircraft.com/cng/
Kinda surprised by this, but can't tell if the 7 hour claim is CNG only or CNG + LL tanks from the story:
Q: How long can you fly the Husky CNG on full fuel tanks?
A: The demonstration aircraft can be flown approximately seven hours at a 65 percent power setting.
Q: What does GGE mean and how does that relate to AVGAS?
A: GGE stands for ?gas gallon equivalent,? that is the amount of compressed natural gas it takes to equal approximately one gallon of gasoline in terms of energy. One GGE of natural gas is 123 cubic feet and weighs approximately 5.66 lbs. vs. 6.01 lbs. for 100LL AVGAS.
07-30-2013, 05:29 PM
Senior Curmudgeon
So the fuel is close in weight, not surprising considering they both come out of the same hole in the ground.
What comes immediately to my mind is;
What is the tank weight????
If it is hard to find Mogas at an airport, what do you think it is going to be like to find a CNG pump??
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
07-30-2013, 05:40 PM
I saw these guys yesterday. I was going to stop and ask the same question about the tank. I'm also curious how they maintain a consistent pressure. I'm going back on Thursday, I'll ask when I go by.
Gil Brice
McKinney, TX EAA-1246
RV7 - Working on fuse, fuel, brakes etc...
07-30-2013, 05:59 PM
Neat
All the way at the bottom of the page...
Q: What is the additional weight of a typical CNG system in a GA aircraft?
A: Of course that depends on the aircraft, and the CNG system being installed. The tank is definitely the largest factor. For example the all-composite “Type 4” tank we installed for this demonstration aircraft has a GGE of 9.2 gallons (35 liters) and weights 95 lbs. empty. In this rapidly advancing field, tanks keep getting lighter and are available in a variety of capacities with even greater weight efficiencies. The balance of the non-structural materials is perhaps 10 lbs.
Given the tank capacity of 9.2 gallons I suspect their 7 hour claim is burning avgas. Still. Neat stuff. I've driven natural gas vehicles and you can't tell the difference in any way.
James Bagley Jr
RV6A flying
RV6 #2 tail done and wings done
07-30-2013, 06:07 PM
Senior Curmudgeon
After reading the linked info.........
So, the full tank weighs just under 150 pounds, and it seems that you would usually have to take it somewhere to fill it.
Then, put it back in the plane------oh my aching back
Here is an interesting quote lifted from the link, " We have noted several performance advantages using CNG over aviation gasoline. One is increased power output given that octane rating of natural gas is typically 138 vs. aviation gasoline?s 100."
Am I the only one who has a bit of trouble with this statement???
Mike Starkey
VAF 909
Rv-10, N210LM.
07-30-2013, 06:55 PM
Don't you just steal the bottles off your grill and throw them in the back seat?
Actual repeat offender.
07-30-2013, 07:32 PM
Senior Curmudgeon
At 40 or so pounds full, not an issue.
Also, the BBQ runs on propane, not CNG.
Mike Starkey
VAF 909
Rv-10, N210LM.
07-30-2013, 09:11 PM
Originally Posted by Mike S
Here is an interesting quote lifted from the link, " We have noted several performance advantages using CNG over aviation gasoline. One is increased power output given that octane rating of natural gas is typically 138 vs. aviation gasoline’s 100."
Actually, that's about right. It varies from around 125 to 140 depending on the exact mix, but the common "pipeline" gas running into peoples homes and compressed for CNG is typically going to yield 135 octane, plus or minus a couple points.
The increased power output is a bit of a stretch - cube for cube and all other things being equal, CNG engines normally deliver about 80% of the horsepower that an equivalent gasoline engine will at the same RPM and manifold pressure.
07-30-2013, 09:44 PM
Senior Curmudgeon
Exactly what I was referring to.
Horse power is not effected by octane. http://www.whitfieldoil.com/www/docs...p-racing-fuel-
Mike Starkey
VAF 909
Rv-10, N210LM.
07-31-2013, 11:20 AM
Correct, but higher octane fuels have higher detonation margins can be run leaner and with more advanced timing, which directly leads to more power.
Ian
