Old 07-26-2013, 02:25 PM
sneedrv-6 sneedrv-6 is offline
Default Spark plugs
Trying to see what sparks plugs are supposed to go in the 0360-a1ad (9.5 compression) with air flow performance injection system engine. The top plugs are on a bendix mag and would like to get new correct plugs. Searched lycoming manual with no luck, searched the forums with no luck (1 dead link to lycoming). Currently I am running unison 40E's. Crazy that a 30k engine does not have the recommended plug in the manual and no phone number on lycoming's site.
thanks for any input,
Jason
RV-6
Awesome aircraft photography!
HTTP://Sneedimages.com
Old 07-27-2013, 03:28 AM
deek deek is offline
I would ask the engine builder what plugs they recommend. With 9.5:1 slugs I'm afraid Lycoming will defer to your engine shop.
'83 LongEZ - N888EZ 3,671 hours
'89 LimoEZ - N26EZ 686 hours (sold)
A couple of Glasairs and a Lancair 320...
Next: a RV14 need something to build
Old 07-27-2013, 09:58 AM
AK4x4's Avatar
AK4x4 AK4x4 is offline
Default Spark plugs
The plugs listed in the parts catalog for that engine are REM40E's. The most current list of approved plugs (Lycoming SI-1042Z) shows the REM37BY, REM38E, and REM40E as approved. However this doesn't really apply as your engine isn't stock. The engine builder should know the correct plug. If I were to recommend a plug for the engine I would use the Tempest UREM38E if the plug leads were 5/8" thread or URHM38E if the leads are 3/4" thread. This assumes that the cylinders are short reach (between 3/8" and 7/16" ish of threads in the plug holes) plug type. Good Luck, Russ
Russell Brown
A&P/IA
"Happiness may never be sensibly pursued as an end in itself, because happiness is the by-product of achievement." -- Northcote Parkinson (paraphrase)
Wasilla, Alaska
