Old 07-24-2013, 06:17 PM
celstar's Avatar
celstar celstar is offline
Default Low CHT and low EGT on cylinder #1
Ok, just out of a very good and no problem annual. After the annual done by a A&P I have been flying a bit and thinking that I have some backfire on deceleration coming in from flying around. More then I remember and has been to the point of being able to feel the plane miss or hesitate a bit but only at low rpm flying. So we changed my plugs out both top and bottom, top EI Lightspeed 3 and bottom mag. Took it back up and seemed to be back to normal and great. Put another 1 hour or more on it now and seems to have come back, I then started looking at CHT and EGT and noticed in cruise my number #1 cylinder's EGT and CHT are 100 degrees or more lower then the rest. Any ideas?
David Herrmann
RV-7 N174DH built and sold
RV-8A N369DP purchased and flying/ Sold
RV-8 N3170L purchased and flying/ Sold
RV-3B N313RV purchased and flying Sold
RV-4 N488TW Flying Sold
1946 J3Cub all stock and original flying Sold
1943 Meyers OTW-160 sold
1997 RV-4.5 N221TM wow, sold ��
Old 07-24-2013, 07:28 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Carb or F.I.??
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 07-24-2013, 07:31 PM
celstar's Avatar
Default Carb
Sorry, carb.
Carb or F.I.??
David Herrmann
Old 07-25-2013, 07:43 AM
airguy's Avatar
airguy airguy is offline
Check for an induction leak - if that cylinder is running very lean it would explain both the low temps and the backfiring.
Old 07-25-2013, 08:17 AM
celstar's Avatar
Default Low CHT and EGT
I thought that if it was a induction leak I would have low CHT but higher EGT?
David Herrmann
Old 07-25-2013, 08:26 AM
Mike S's Avatar
Senior Curmudgeon
All depends on how bad the leak is.
Get enough air in there, and it will not fire at all.
Mike Starkey
VAF 909
Rv-10, N210LM.
