Go Back   VAF Forums > Avionics / Interiors / Fiberglass > Autopilots
Old 07-09-2013, 04:37 AM
witek witek is offline
Default TruTrak servos compatibility Basic Servo B, DSB-B
Hello,
Does anyone know which EFIS or AP is compatible with TruTrak servos Basic Servo B, DSB-B?
I bought these servos installed in RV7A QB kit, originally completed and started by previous owner.
I would like to link the servos directly to GRT S200SX8 (no additional AP unit). Is it possible?
Regards
Witek
Old 07-09-2013, 07:29 AM
TrutrakTech TrutrakTech is offline
Hi Witek,
Our servos are compatible only with our autopilot controllers. Thanks!
Trutrak Tech Support
trutrakap.com
Old 07-09-2013, 02:15 PM
Hi Lucas,
Which controller do you recommend for these servos?
I would prefer rather simple device.
Witek
Old 07-10-2013, 10:08 AM
If you just want a simple two-axis autopilot, you could use the Digiflight II VS. It comes in either 2 1/4 inch round or our flat pack formats. The DII VS controller can be purchased for $1150. Thanks!
trutrakap.com
Old 10-29-2013, 08:57 AM
Hello Lucas,
Can I use external GPS signal to steer TruTrak DII VS controller?
Where can I buy the DII VS controller for the price you mentioned above?
Witold
Old 10-29-2013, 02:11 PM
Yes, nearly every aviation GPS will work for interfacing to the DII VS. As long as it has a NMEA or Aviation format output at 4800 or 9600 baud, it'll work.
You can purchase the autopilot controller directly from us or any of our dealers. Thanks!
trutrakap.com
