Old 06-16-2013, 09:26 AM
pietermk pietermk is offline
Default Page 10-08 Static lines
Hello group,
I am putting the static lines in and in some builder logs I see people using Blue RTV silicone. My question is where to put the silicone and why. Is it to glue the tube to the ports and other parts so they can't come off? Secondly I am concerned about silicone getting in the way of the "airflow". Would the static pressure be influenced if some silicone would block the opening of a tube or connector piece?
thanks and happy fathers day
Peter
Peter
See my builders log, I received the tail kit on February 2011, still working on it. I need more free time Dues paid for 2017
http://www.mykitlog.com/PeterRV12/
Old 06-16-2013, 10:08 AM
Phantom30's Avatar
Phantom30 Phantom30 is offline
Peter,
Just did this step. Partially start the tubbing onto the static port rivet...then apply the rtv to tubbing and rivet (surrounding the rivet area) to hold tubbing securely... This way you won't get any rtv inside the tubbing.
Forgot add...once you rtv the tubbing/rivet; slide the tubbing all the way onto the rivet.
Ric Dickison
307 (CAB) Phantom
Search and Destroy (Can
Tho RVN)
Distinguished Flying Cross Society Member
CH-47 & UH-1H "Driver"
Rotax 9 Series Service IRMT
RV-12 Kit#729 "N312RD" is now a full functioning fun machine!! Thanks Van for fulfilling my dream😎
2018 Dues Paid
Old 06-16-2013, 11:10 AM
Originally Posted by Phantom30 View Post
Peter,
Thanks Ric great advise.
Peter
Peter
Old 06-18-2013, 03:43 PM
jlfernan's Avatar
jlfernan jlfernan is offline
Also be sure you are using non-corrosive RTV. Some RTV out there can be harmful to aluminum.
http://www.mykitlog.com/JorgeF
Jorge Fernandez
Spruce Creek, FL
Old 06-19-2013, 09:42 AM
Well I have to go back and see as I have already used it. Thanks for the tip
Peter
Peter
Old 06-19-2013, 11:58 AM
I suspect the corrosive stuff is the bath tub caulk that smells like vinegar (acidic?). Does anybody know if that's correct? I get my RTV at Auto Zone. It doesn't have the vinegar smell and I haven't noticed any corrosion.
Old 06-27-2013, 07:07 AM
John-G John-G is offline
Default Use Sensor Safe
A little late on this but it is my understanding that if the RTV sealant says it is ?sensor safe?, you are using a non-corrosive form of sealant ? have not heard anything to the contrary.
I too purchased my RTV at an automotive supply store ... blue Permatex and it states on the tube it is sensor safe. It does not have the heavy vinegar smell that bath and general-purpose silicone sealants typically do.
John
