Old 06-12-2013, 02:56 PM
blahphish's Avatar
blahphish blahphish is offline
Default Cowling with a/c compressor
Does anyone have a photo handy of a stock cowl on a -10 that has an a/c compressor? I'm helping a buddy out and am interested in seeing it from the viewpoint of looking into the air inlet. Just curious if people typically make ramps or just leave it as is or something else. Thanks in advance!
Brian Unrein
RV10 N42BU 900+ hours!
First flight 6-16-12
https://N42BU.com
Old 06-12-2013, 04:48 PM
Jesse's Avatar
Jesse Jesse is offline
I don't have pictures, but RDD Enterprises makes a composite baffle that seals between the engine and the cowl below the alternator and compressor and above the airbox scoop. It works very well in my experience and looks much better than a modified ramp, IMHO.
Jesse Saint
Old 06-13-2013, 12:29 PM
Space Cadet's Avatar
Space Cadet Space Cadet is offline
Default Which compressor, side?
There's a couple different compressor options out there Brian. Which one are you looking for? Which side of the engine, and above or below?
Dwight
RV-10 #40762 - 100 hrs+
Denver, CO
Old 06-13-2013, 01:53 PM
tturner tturner is offline
Brian
There is new a fellow in the Falcon RV group that has a 10 with air-conditioning. This name is Tim Morris and I think the aircraft is based in Lagrange. It has a bulge in the cowl where the compressor is.
Tommy Turner
Fayetteville GA
RV-4 sold
RV-6 sold
RV-8 Flying
RV-14A building
Old 06-13-2013, 02:31 PM
blahphish's Avatar
Thanks for the replies so far everyone. The particular compressor I'm working with is mounted on the left side and is just about even with the spinner, just a tad lower. It is highly visible when looking into the left air inlet.
Brian Unrein
https://N42BU.com
Old 06-13-2013, 02:51 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
So, it is right under the prop gov??
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 06-13-2013, 03:03 PM
blahphish's Avatar
Yep! Not sure if thats very standard or not but thats what I'm working with.
Brian Unrein
https://N42BU.com
Old 06-13-2013, 06:26 PM
dmaib's Avatar
dmaib dmaib is offline
That sounds like the newer Flightline AC compressor mount. The original ones had the compressor on the right side and the alternator on the left side with belt tension pulleys.
I have the newer mount and don't have any cooling problems, but it looks kind of funky with the compressor sitting right there in the intake. I modified the ramp to accommodate the compressor and it does not look real pretty, but works fine. Sorry I don't have any photos available.
David Maib
RV-10 N380DM
New Smyrna Beach, FL
VAF Paid 1/21/2020
"In '69 I was 21, and I called the road my own"
Jackson Browne
