Old 06-11-2013, 08:30 PM
PCHunt PCHunt is offline
Originally Posted by VETE76 View Post
as of 10:30 am 2day I now have a strong running io360 thanks to Dave l. the mags were timed perfect but the internals were timed to a different cylinder. he took the mags apart and put them together the correct way, installed them, set them and said 100% guarantee it will start 1st time especially with that slick start u added. ..............fred
I could be wrong, but the internal mag timing is setting the E-gap. Internal timing is for the mag only, and doesn't reference any cylinder. You time the mag to the engine after setting the internal E-gap, which is when you need to time the mags to TDC on Cyl #1, using the correct advance, usually around 25 degrees BTDC.
Are you saying that the leads weren't attached to the mags correctly, so that they went to the wrong cylinders?
Pete Hunt, [San Diego] VAF #1069
RV-6, RV-6A, T-6G
ATP, CFII, A&P
2020 Donation+, Gladly Sent
Old 06-12-2013, 05:42 AM
VETE76 VETE76 is offline
it just like on a car engine the
'gear on mag and drive gear from engine must be mated exactly right. mine were 180 deg miss aligned
so when #1 was in position to fire the mag sent the spark to #4 intake stroke
Old 06-12-2013, 05:57 AM
Auburntsts's Avatar
So that begs the question as to how did it ever run on the test stand?
PP ASEL-IA
RV-10 N728TT - Flying!
WAR EAGLE!
Old 06-12-2013, 06:02 AM
that's what I asked Lycoming. awaiting answer
Old 06-12-2013, 06:12 AM
airtractor8 airtractor8 is offline
mmmm, read post #22
