Go Back   VAF Forums > Model Specific > RV-6/6A
Old 05-18-2013, 03:28 PM
ChiefPilot's Avatar
ChiefPilot ChiefPilot is offline
Default Performance
I took my first "real" X/C today, flying from South St. Paul MN/KSGS to Beloit WI/44C - about 220 miles or so. On the way out, I did 171kts TAS at 9500' on 8.2 gallons an hour. On the way back at 10,500, I did 169kts TAS on 7.9 GPH. This is with an IO-360-B1B (180HP), dual PMAGs, and Hartzell BA prop. Not sure if these performance numbers are good/bad/ugly, but I'm pretty happy with them!
I have the wheel fairings, etc. installed but still have to install the upper intersection fairings. That will happen this week. Then on June 1st it's off to the paint shop. After that, I'll re-do all the performance tests from phase one.
As I said after the first flight, "Had I known it was this much fun I wouldn't have taken so long to build it!"
Brad Benson, Maplewood MN.
RV-6A N164BL, Flying since Nov 2012!
If you're not making mistakes, you're probably not making anything
Old 05-18-2013, 05:56 PM
AlexPeterson's Avatar
Brad, those are almost exactly what I get for TAS/fuel burns as well. Not sure I'd get those speeds at such high altitudes as you did, but at 7 to 8k' I'd be right on those parameters.
Alex Peterson
RV6A N66AP 1700+ hours
KADC, Wadena, MN
Old 05-18-2013, 05:57 PM
Default Sounds pretty outstanding to me
That was my top speed (170.67 KTAS) burning well over 10 GPH. RV-6A, O-360 A1A. Well done.
Bob Axsom
Old 05-18-2013, 06:59 PM
miyu1975's Avatar
miyu1975 miyu1975 is offline
Very nice...what rpm were you running. I typically cruise at 2400, burning 8gph, LOP, and see a consistent 160 TAS.
Ryan Allen, CFII
RV7 N612RA, flying since july 2012
E-170/175
RV10 Tail Kit complete, Wings 90%, fuse on order
Acro Sport 2, building
Old 05-18-2013, 09:58 PM
ChiefPilot's Avatar
Hmmm, now I'm suspicious of my numbers. Although I did produce an airspeed correction factor during phase one, I'm wondering if it is still valid after the addition of all the fairings & re-rigging or if the numbers are a true reflection of the actual performance.
Still, it was a fun day and in relative terms I am very happy with the speed difference vs. no wheel pants/gear leg fairings. If I had more time before I have to drop it off at the paint shop I'd re-run the test cards now but I think they will need to wait until after.
I'll be sure to post back w/findings.
Thanks all!
Old 05-19-2013, 05:51 AM
Brad, as you probably did during your initial testing, the final arbiter of speed is to do four way (gps ground track compass directions) speed runs, keeping everything constant for a minute or so each way. There are excel sheets out there that will get exact TAS based on the four speeds.
Alex Peterson
KADC, Wadena, MN
Old 05-19-2013, 07:33 AM
ChiefPilot's Avatar
Yes, that's what I did in phase one. I made speed runs at multiple airspeed and used the NTPS spreadsheet to determine the error coefficient for my installation. My assumption is that the IAS/CAS error is not affected by altitude, but perhaps this is not correct.
It doesn't seem likely that the addition of fairings would change that, but I've learned lots of things during this project that seemed unlikely to me so...
Old 05-19-2013, 07:56 AM
tsneidin tsneidin is offline
Default Who needs paint
Says the other unpainted RV at Beliot yesterday. I enjoyed the sharpie comments written on your plane, particularly "Bernoulli was here" written on the top of the wing.
Do you have paint scheme picked out? Mine is bare yet mostly because I can't decide colors and such.
Todd Neidinger
RV-9 Flying
Old 05-19-2013, 02:33 PM
pierre smith's Avatar
As your airspeed increases, the drag is more pronounced. A Cessna 150 only gains 3 MPH with wheelpants, while we, at near 200, gain near 9 MPH...as the airspeed doubles, the drag squares! So don't discount those upper intersection fairings.
Best,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 05-19-2013, 09:19 PM
ChiefPilot's Avatar
Thanks! I'm going to miss the ability to write on it whenever I feel like it; perhaps a white board marker will work :-)
Yes, I've been refining an original paint idea for several years. It's almost completely finalized. The thing is I'm rather picky about it - it took me 11 years and 8 months to finish the thing so I'm not excited about just any paint scheme being applied to it.
Sorry I missed you there - perhaps we'll meet there next year or at another fly-in in the area!
