The sniffle hose is cut to fit and the fire sleeve is to cover the throttle cable where it passes over the exhaust. The battery most builders use is the Odessey PC 680. The battery fits the holder perfectly. I ordered and mounted mine fairly early on and then deleted it from the final fwf kit order. Vans will work with you on things like that so you can install items when it makes sense to you.
Bob B
RV-7A QB slider - IO 360 M1B Hartzell C/S prop w/Dual 10" Dynon Skyviews - Classic Aero interior. Florida (SFB) based. 170 hrs TT .
