04-22-2013, 04:37 PM
RV-8 deck angle
Grove gear legs and tail wheel installed, the fuselage sitting on hangar floor looking like an airplane.
The main gear looks a bit tall resulting in a deck angle of 12 degrees.
Could someone measure their deck angle on the canopy rail just for comparison?
Thanks.
RV-12 Build Helper
RV-7A...Sold #70374
The RV-8...Sold #83261
04-22-2013, 05:08 PM
My finished and flying RV-8 shows 11.1 degrees at the canopy rails. The tire inflation, tread wear, and its standard Vans gear probably accounts for the delta
04-22-2013, 05:09 PM
Just checked mine. Grove 1 piece gear, Bell fork and engine not installed. 12.6*
Bill Settle
RV-8 N38CW (Reserved)
Hi David,
Just measured mine, 11 degrees. I have the grove gear with a Bell tail wheel fork and stock wheel, that may account for the 1 degree difference.
Bill
RV-8
04-22-2013, 07:01 PM
Thanks guys, my airplane is ok.
RV-12 Build Helper
RV-7A...Sold #70374
04-23-2013, 01:23 AM
Standard Gear Legs
Does the standard (Vans) gear legs give the same angle (aka. height above ground) as Grove?
Peter Vernon
Eagle Heights, Queensland, Australia
RV8, QB Wings, Standard Build Fuse (85% @ April 12)
email: pve95448@bigpond.net.au
Paid dues ... pleased to support DR
04-23-2013, 05:55 AM
Peter,
I am reasonably certain it does. The differences we see here are not much and may be the result of the tail wheel variances.
My brain is accustomed to looking at an "A" model and first impression of seeing the 8 on its wheels is WOW, that nose sure is high.
RV-12 Build Helper
RV-7A...Sold #70374
04-23-2013, 07:11 AM
Engine, prop on it yet? Bit of weight there...likely spring the gear out a tad.
RV-8 Flying
1,235th flying RV8
SARL Race#95
SnF Homebuilt Judge
04-23-2013, 07:15 AM
Aluminum legs, lower modulus, more deflection when loaded.
Dan Horton
RV-8 SS
Barrett IO-390
