Go Back   VAF Forums > Model Specific > RV-9/9A
Old 04-19-2013, 10:20 AM
savas savas is offline
Default 9 Aeros?
I am quite aware, of restriction of aeros on a 9.
Question is, is this restriction on any/all type of maneuvers .
Thanks for replies in advance
Old 04-19-2013, 10:56 AM
luddite42 luddite42 is offline
I don't know what the regs state in other countries, but here, the legal definition of "aerobatics" is vague and could mean just about anything, including a steep turn if you want to apply the regs verbatim. You don't have to be upside down, or +/- 30 degrees of pitch, or +60 degrees of bank to meet the legal definition of "aerobatics" (in the States at least). It's all interpretation. Of course, most people associate "aerobatics" with loops, rolls, and spins. All aerobatics is basically infinitely complex variations on these three maneuvers. The RV-9 is not approved for spins. So that leaves loops and rolls. Even though loops and rolls aren't mentioned in the FAA's definition of aerobatics, these will be considered "aerobatics" 100% of the time by anyone in a position to take action against you. What other types of "aerobatic" maneuvers are you wondering about?
Old 04-19-2013, 12:54 PM
What I wanted to know, is if the 9, structurally can handle rolls, loops and wing overs, that's all
Old 04-19-2013, 12:56 PM
WAM120RV WAM120RV is offline
Default Aerobatics
Aerobatics is the practice of flying maneuvers involving aircraft attitudes that are not used in normal flight.
There thats a simple definition to work to....... if you want to do aeros buy a 3,4,6,7,8 then there is no issue!!
My 9 though is a great tourer!!
http://www.aerobuilder.blogspot.com
Steve Arnold
England
In completion stage of Loehle P5151
Built and now Flying G.BVLR Vans RV4
Rebuilt G.BDBD Tailwind
Rebuilt G BVTN Kitfox
Built G CDCD RV9A with WAM120
Riveted wings on Glastar G.LEZZ Now (G. SKUA)
Old 04-19-2013, 01:03 PM
Sure it can. You can safely loop or roll just about any airplane. You just have less strength margin and less margin for screwups compared to airplanes designed for aerobatic stress. Capable and suitable are two different things though.
Old 04-19-2013, 01:33 PM
airguy's Avatar
airguy airguy is offline
And I sure wouldn't want to learn aeros in an airplane with less margin - if someone wants to do aerobatics in a 9/9A they had better already be an expert in them to be able to keep them gentle and stay well within the structural limits. The 9 frame is simply not built for aeros.
Old 04-19-2013, 02:02 PM
Originally Posted by airguy View Post
...if someone wants to do aerobatics in a 9/9A they had better already be an expert in them to be able to keep them gentle and stay well within the structural limits.
"Expert" depends on your frame of reference I guess. It actually takes very little skill and minimal training to reach the point of consistently and safely doing sloppy loops and rolls well within even the Utility G-limits in an RV. But it does take some very basic introductory aerobatic training and practice. The RV-9 is not a suitable airplane for this type of training, self-taught or otherwise. The FAA has already set the paradigm for type-certificated airplanes being stressed to +6/-3G to be approved for aerobatic maneuvers. EAB aircraft don't fall under these requirements, but it would be irresponsible and unprofessional of Vans Aircraft to allow aerobatics in a design that the FAA would not allow aerobatics to be performed in if it was otherwise type-certificated. Aerobatics in aircraft not designed for it is a slippery slope in a lot of ways. You need to know what you're doing to peform safe aeroatics in any airplane, regardless of its load limits. You don't need to be Bob Hoover, but you do need to be competent enough. The problem is, many pilots don't know how incompetent they are, so they shouldn't be encouraged to do aerobatics in non-aero stressed airplanes. It's one of those, "if you have to ask..." sort of things.
Old 04-19-2013, 02:13 PM
Jamie Aust's Avatar
Jamie Aust Jamie Aust is offline
YES
Jamie lee
Brisbane, Australia
RV7A - Now Flying.
0-360,carb,catto 3 blade.
VH-XJL
Old 04-19-2013, 02:54 PM
FlyingArcher's Avatar
FlyingArcher FlyingArcher is offline
Default Made wing overs in factory -9A
During my demo flight at Oshkosh 2009 in the factory -9A, the pilot demonstrated the plane handling qualities by making a couple of wing overs, stating that these maneuvers were not considered aerobatic.
They were quite impressive to me anyway and I loved it.
Daniel Mouly
VAF #778 - [2013 payment done]
RV-9A Emp. & Wings 95%, Fuse 70%
Austin Healey 3000 MKIII fully restored
LFCD (Andernos Les Bains), France
Construction Log comments in French (not really up to date, sorry)
Old 04-19-2013, 04:40 PM
Mel's Avatar
Mel Mel is offline
"91.303 Aerobatic Flight.
For the purpose of this section, aerobatic flight means an intentional maneuver involving an abrupt change in an aircraft's attitude, an abnormal attitude, or abnormal acceleration, not necessary for normal flight."
This statement should be in the operating limitations for all US RV-9 aircraft.
For US aerobatic category an aircraft must be stressed for +6/-4 Gs.
The RV-9, -10, and -12 are not designed to these limits.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
