04-12-2013, 04:06 PM
Wild dimple. Need advice
So the dimpler slipped and I have an extra hole. I know this is relatively common and I know how to deal with it normally. However, this happened at the edge of my flap skin and there is a crack propagating to the edge. In addition. This hole is on the leading edge of the flap skin, right over the spar and under the corresponding hole of the leading edge skin. I'm not 100% sure how to best deal with this and would appreciate some advice.
Thanks for any help,
-Joe Wilbur (N520LW)
Phase II - 11/2017
First flight - 8/2017
RV-10 Build Log
04-12-2013, 05:56 PM
Since it is on the edge and it is cracked, my advice is to replace the skin. It is not that large a piece and will not be expensive to ship. I always took the road of replacement when I was in doubt.
Bill Peyton
RV-10 - 1125 hrs
N37CP
First Flight Oct 2012
Aviation Partners, LLC
04-12-2013, 06:00 PM
Senior Curmudgeon
My gut feeling is replace, but you should check with Vans--------they may have you put a rivet on either side of the one in question, in this skin only, and then cover it all with the other skin as per normal. Or something else.
But that should be their call.
Good luck.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
04-12-2013, 06:02 PM
You've effectively stop drilled it, so it's not likely to propagate. I suspect Van will say to put a rivet on either side, and cover it with the overlapping skin.
Rob Prior
04-12-2013, 07:44 PM
I'd replace the skin.
Remember keep one hand pressing the skin down. I learned this
lesson too.
Ray Tonks
2020 Donation Paid
Titan IOX-370, Dual PMAGs, 9.6:1 Pistons, FM-150
RV-7 Fuselage in progress
* Cabin Interior - In progress
RV-7 SB Wings
* Both Wings fully skinned
* Fuel Tanks Complete - No leaks finally
* Ailerons Complete
* Flaps Complete
RV-7 Empennage - Complete (a little fiberglass work left)
Vans Training Kit # 2 - Complete
RV-7 Preview Plans
Vans Training Kit #1 - Complete
EAA Sheet Metal Class - Complete
04-12-2013, 07:52 PM
rivet spacing
Rivet spacing is not critical to the strength of the piece so rivet on either side and cover the mistake with a filler when you paint.
04-12-2013, 10:21 PM
I'd agree replace 🙀
Ed Martin
Bluskydtl
RV7
DKB
Donations 1/19 & 6/19
04-12-2013, 11:33 PM
Note to Van's
I sent a note to Van's.
Personally, it doesn't really seem to me like it needs to be replaced. As has been said, the crack isn't going to propagate. I think a rivet on each side plus maybe nibbling out a small wedge and smoothing out the jagged bits in there seems like a reasonable (and sufficient) solution. And then the leading edge skin goes on top covering up all the ugliness.
I'll post the response from Van's when I get it.
Phase II - 11/2017
RV-10 Build Log
04-15-2013, 12:53 PM
The response from Van's
From Ken at Van's:
Welcome to the club. EVERYone does this at least once. Dimple the real hole, clean up the messy edges with a bit of 600 sandpaper, put a rivet in it and do a little body work before you paint. You can add an extra rivet to one or both sides of the !%!# hole if you like.
Phase II - 11/2017
RV-10 Build Log
04-24-2013, 02:12 PM
I propose this idea that may interest you
do not forget to make a small spacer to compensate for the thickness of the cut sheet
must translate handwritten notes which are written in French
