Go Back   VAF Forums > Model Specific > RV-6/6A
Old 03-27-2013, 06:32 PM
FitzRX7 FitzRX7 is offline
Default RV-6 Wing Screws
Hey guys, I'm new here and I'm trying to buy a flying RV-6.
We noticed that there are some screws that seem to be called for in the plans missing from underneath the wings, where they attach to the belly skin of the aircraft.
I've been told various things as to that they are important and that they are not, and I'm just trying to get to the bottom of it.
Thanks!
Old 03-27-2013, 06:42 PM
Sid Lambert Sid Lambert is offline
If the wing skin meets the belly flush then I see no reason to put them in. Mostly the screws help make the skin flush. I guess they could flex over time and crack if it is not flush but not really a huge concern.
Sid Lambert
RV-7 Sold
RV-4 - Flying - O-320 Fixed Pitch - Red over Yellow
Old 03-27-2013, 07:09 PM
This is actually where the belly skin overlaps the wing. I'm never built one, but from my rookie level of reading plans it appears like 10-ish screws that go through each belly skin->wing skin->inner wing rib and attach to nutplates mounted in the wing. 20 or so screw/nutplates in total, 10 each side.
Old 03-27-2013, 07:38 PM
JonJay's Avatar
JonJay JonJay is offline
This has come up before, perhaps with the same airplane. They are absolutely structural and required.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 03-27-2013, 07:45 PM
JonJay's Avatar
http://www.vansairforce.com/communit...ht=Wing+screws
Bucker Jungmann
RV1 - Proud Pilot.
But I was told that there are no airworthiness directives or service bulletins that exist for this issue. (I'm not really sure what all that means, it's just what I was told)
How long would it take to fix something like this?
Old 03-27-2013, 07:49 PM
JonJay's Avatar
It is not a service or airframe issue, it is a construction issue. Who knows what impact it may or may not have on the strength of the wing. I posted a link to a post about a 7 with the same issue.
The fix would require wing removal, not an easy job. I would be more concerned with what else the builder felt was "unnecessary".
Bucker Jungmann
RV1 - Proud Pilot.
Old 03-27-2013, 08:45 PM
Snowflake's Avatar
Has anyone got any pictures of this? I'm having a hard time visualizing it and I own a -6... But I didn't build mine either. Doesn't the wing root fairing go all the way around? Guess I'll find out again at this year's annual (due in about a week...).
Rob Prior
Old 03-27-2013, 08:46 PM
Steve Barnes Steve Barnes is offline
Default Absolutely JonJay
I fully concur and for all the same reasons. If you call Van's and ask them, the answer is, it absolutely is a structural matter.
Steve "The Builders Coach"
Old 03-27-2013, 08:53 PM
ChiefPilot's Avatar
ChiefPilot ChiefPilot is offline
No, underneath it stops just aft of the tanks.
Brad Benson, Maplewood MN.
RV-6A N164BL, Flying since Nov 2012!
If you're not making mistakes, you're probably not making anything
