Old 01-19-2013, 08:05 AM
Mighty fine work, Axel.
Sorry about the new radio not working. Maybe it is just something in how you checked it.
RV-12 Build Helper
RV-7A...Sold #70374
The RV-8...Sold #83261
Old 01-19-2013, 09:19 AM
boom3's Avatar
boom3 boom3 is offline
Originally Posted by gasman View Post
Get it fixed at your local avionics shop for less than $200.00
I called everyone around here and no one would work on my SL-30. They all said my only option is Garmin.
Jeff Bloomquist
Sumner, WA
PP-ASEL, IR
RV-7A
Flying
1150 Hours
Old 03-25-2013, 01:53 PM
AX-O's Avatar
AX-O AX-O is offline
Adding some info regarding the difference between the roll and pitch auto pilot servos.
http://www.grtavionics.com/forum/viewtopic.php?f=6&t=96
Axel
RV-4 fastback thread and Pics
VAF 2020 paid VAF 704
The information that I post is just that; information and my own personal experiences. You need to weigh out the pros and cons and make up your own mind/decisions. The pictures posted may not show the final stage or configuration. Build at your own risk. Further more, these are my opinions and not those of my employer.
Old 03-25-2013, 02:59 PM
AX-O's Avatar
I am starting to run out of parts. I can almost count the number of parts required prior to the ?big move?. I am starting to do ?flare? type stuff. Some pics of progress over the last few weeks are shown below. I have also been doing functionality check on some the systems. All smoke is still remaining contained in the avionic boxes.
Wiring:
This last plugs allows me to disconect all my avionics and pull out the tray so I can have access during Maint functions.
Side panels:
These two plugs allow me to remove the control panel in case of Maint.
The small holes are for pockets. The large ones are for the copilot comm plugs.
Auto pilot:
The nice thing about a fastback, just a little more space. My wife came out to garage looking for me and freaked out.
Magnetmeter:
Axel
Old 03-25-2013, 03:54 PM
bkthomps bkthomps is offline
looking great!
Old 03-25-2013, 05:32 PM
rv4ross rv4ross is online now
Axel, Keep the pictures coming, it inspires me to keep moving on my 4. Not at the stage your at, but will be this summer, I hope!
Ross Scroggs
Locust Grove, GA
RV-4 #3911 Fuselage
Old 03-25-2013, 06:15 PM
AX-O's Avatar
Ross Scroggs
Locust Grove, GA
RV-4 #3911 Fuselage
Wilco. I am glad it helps you out. Others constantly give me motivation; the least I can do is pay it forward to those that are at an earlier stage on their build.
Axel
Old 03-25-2013, 10:50 PM
AX-O's Avatar
Here are a few more pics of the pockets and the cockpit lights installed. the lights can rotate as required. The straps are for the head set when ingressing or egressing the cockpit.
Axel
Old 03-26-2013, 07:47 AM
81270 81270 is offline
Love that map pocket just below the elbow pad (last pix).... if that's what its
Peter Vernon
Eagle Heights, Queensland, Australia
RV8, QB Wings, Standard Build Fuse (85% @ April 12)
email: pve95448@bigpond.net.au
Paid dues ... pleased to support DR
Old 03-26-2013, 12:14 PM
AX-O's Avatar
The pilot pockets were designed to hold charts and standard size paper. The co pilot ones were designed to hold one gossip magazine. There will be an additional pocket on the back of the pilot seat to hold an ipad.
Axel
