Old 03-07-2013, 09:41 PM
Tumper's Avatar
Tumper Tumper is offline
Default Tip: How to build a little critter guard
Here is a simple trick that others might be interested in. As spring approaches so do the little flying nesting critters. I have this fear of being attacked by wasp or bees or potentially getting scared to death by a dirt dobber in the cockpit during flight. Maybe there are a lot more entry points, but the place I am most concerned the little critters will enter is the air vents.
I tried to come up with something that would be light, simple and easy to install.
1) Take a piece of lightweight 1 ?? PVC pipe and cut two 1? pieces.
2) Find some screen wire (this was the hardest part of the process since I didn?t want to buy enough to cover an entire screen door). Below is a description and item number of the screen I used from McMaster-Carr.
3) Cut a 2? x 2? square of screen and attach it to the PVC pipe using ProSeal (or silicone would probably work).
4) Wait a week or so for the ProSeal to dry.
5) Trim the edges with metal sheers and sand the outside smooth with your trusty belt sander. By the way the stink from sanding ProSeal will make you think your teenage son just entered the room after a meal of?you get the idea. (dr; you?ll understand this better in a few years)
6) Remove the hose from your vent and insert the newly made vent screen in the line and reattach the hose.
7) Done.
I am going to add this disclaimer; I am still in the building phase so I haven?t actually tested this creation during flight. But if it doesn?t work to your satisfaction it can easily be removed.
Corrosion-Resistant 304 Stainless Steel Woven Wire Cloth, 15 X 15 Mesh, .010" Wire Diameter, 12" X 12" Sheet. 73% open area, item number - 85385T62 $5.70 @ mcmaster.com
Dean Eiland
Aubrey, TX
Former Vice President EAA Chapter 1246
RV-9 (yes) N369RV
Mattituck IO-360, C/S Whirl Wind Prop, GRT, Digiflight II, Garmin SL30 & GTX 330 and Hotel Whisky Aux tanks, Bla Bla Bla
Flying
Old 03-07-2013, 10:24 PM
beav's Avatar
beav beav is offline
You can also just fold the mesh over the exit of the NACA inlet and install the duct to hold it in place:
jason
N4VR
RV-7 (Flying)
http://www.jasonbeaver.com/rv7
Old 03-07-2013, 10:53 PM
erich weaver's Avatar
Well, sure, that would be fine for those few folks who don't love working with Proseal any time they have a chance
erich
Old 03-08-2013, 06:29 AM
Fearless's Avatar
Fearless Fearless is offline
Dean
Thats a great idea for someone who needs to retro fit. I pro-sealed some screen onto my NACA duct and trimmed off the excess before I installed them on my plane. Another 9A builder gave me the tip.
Mike
RV-9A Based K6I2
Flying - out of Phase 1
Building RV-12 with brother
Old 03-08-2013, 07:36 AM
Ron RV8's Avatar
Ron RV8 Ron RV8 is offline
Default Another angle on the theme
I just cut a circle of heavy screen and two ~1/4" lengths of 1 1/2 PVC pipe. Split the pipe to allow it to spring into the NACA duct. There's almost enough spring to hold, but I added two small drops of CA on each side to make sure.
Ron Townson
Okanagan Valley BC, Canada
RV-8 Completed Dec 2013
Membership renewed Sept 8, 2019
Old 03-08-2013, 07:41 AM
flyboy1963's Avatar
Default no fair! them 'er fer model aeroplanes!
Ron, you can't use CA (kuhrayzee glew) on a REAL plane.....says somewhere in the rulez!
nice solution!
.............anyone got some nice external plugs for their vents????
Perry Y.
RV-9a - SOLD!....
Lake Country, BC
Old 03-08-2013, 06:59 PM
dmaib's Avatar
dmaib dmaib is offline
Yep! This has worked great for me for more than four "buggy" years in Florida. Suggested by my Tech Counselor, Mike Hilger (of SteinAir fame) back in MN while we were building.
David Maib
RV-10 N380DM
New Smyrna Beach, FL
VAF Paid 1/21/2020
"In '69 I was 21, and I called the road my own"
Jackson Browne
Old 03-09-2013, 12:31 AM
bruceh's Avatar
bruceh bruceh is offline
Default another option
I cut out the screen, put it in the vent and then put a bead of proseal on the edges to keep it in place.
Bruce Hill
2020 VAF donator
Old 03-11-2013, 02:17 PM
ka6dan ka6dan is offline
Thanks for the hint
Just at the right time. Not long from closing the forward fus.
Ka6dan
RV9A
Phase I @ X35 is complete
Paid My 2020 dues. 😃
Old 03-20-2013, 02:58 PM
jocronch jocronch is offline
Default Mesh Sources
Some of the best sources and places to find this mesh - or the 3 that I use most frequently, and I have done a lot of research....
www.grainger.com
http://www.bwire.com/index.html
www.mcmaster.com
Check pricing between all 3 sources - prices can vary greatly from week to week and even day to day - so watch closely!
