Old 03-17-2013, 10:17 PM
rwarre rwarre is offline
Default Boelube
Anyone ever used a product called Boelube for tie rod bearings? Found it at a bicycle shop and was told that Boeing used it on aircraft.
Old 03-17-2013, 11:19 PM
RV6AussieNick RV6AussieNick is offline
Default Cutting lube
Its mainly used for as cutting lube, its also know as Cetyl alcohol http://en.wikipedia.org/wiki/Cetyl_alcohol
Excellent for cutting threads, lathe drilling or slow drilling of hard materials.
Nick Purcell
Licensed on B767, A330 Eng/Airframe
Fixing up RV6, building a Stewart S51
Basically a major overhaul of everything.
Old 03-17-2013, 11:59 PM
OneCharlieKilo's Avatar
OneCharlieKilo OneCharlieKilo is offline
I used it quite a bit during my -6A build. Good stuff.....used it to lube small screws (#6 or #4) before running through platenut the first time to keep from breaking them off, good for running over hinge pins for cowl hinges until you get a few hours on them to loosen them up for getting cowl on or off.
Others can probably chime in on other areas as it was suggested to me by other builders - that's how I discovered it!
Chris
Chris
RV-6A, N731CK, 300+ hrs
Poulsbo, WA
http://rv6aproject.ckhand.com
Old 03-18-2013, 02:45 AM
rjtjrt rjtjrt is offline
There is some more info on this thread as well -
http://www.vansairforce.com/communit...ad.php?t=87591
John
Old 03-18-2013, 05:58 AM
bforsyth bforsyth is offline
Default Boelube
We used it on rod ends, cowl pins, etc on one of our RV9A's. It is very clean and effective, but stiffens up significantly in cold temperatures, to the point that you can feel it in the controls (slight but noticeable). Much more of an issue on the cowl pins in the cold, we cleaned it off and replaced it with our normal lps type lube.
Old 03-18-2013, 06:14 AM
RPorter's Avatar
RPorter RPorter is offline
Very good stuff to use on small screws. Just lightly coat the threads before installing. Makes installing and removing the little boogers much easier.
Ross Porter
A&P Mechanic, Republic Airways
Indiana
First Generation Eagles Nest/Aviation Nation RV-12 Builder/Pilot
