03-14-2013, 12:59 PM
ADSB over DFW
I have a question about ADSB indications that I thought I would toss out and see if anybody can give me the answer.
I just flew out to Abilene and back and went just south of the DFW Class B. On the way out I noticed I was getting all kinds of ADSB traffic indicated around the Class B but almost none inside the Class B. I was receiving anywhere from 4 to 11 ADSB towers with several actually showing up on the DFW airport.
Everyonce in a while I would then get all kinds of traffic inside the Class B. I have ADSB in and out and always received numerous targets around me so I know my equipment was working. Here's what DFW looked like for a while and then it would all just disappear. It has me baffled.
Does anybody have any ideas as to why it's there for a while and then it's not. It was not displaying for the majority of the time.
Jerry "Widget" Morris
RV 8, N8JL, 3,000+ hours on my 8.
VAF #818
Saint Simons Island, GA. KSSI
PIF 2008, 2009, 2010, 2011,2012, 2013, 2014, 2015, 2016, 2017, 2018, 2019, 2020
 I just wish I could afford to live the way I do
03-14-2013, 01:07 PM
This is a guess, I'm no expert. The system only sends you traffic that is near you. But you may be picking up traffic uploads intended for other aircraft. Once those other aircraft (only aircraft with ADS-B out count) move away then those distant traffic uploads stop, and you go back to only those near you.
What do the experts say?
03-14-2013, 01:22 PM
Thread creep.... Wouldn't it be cool if Wing XPro would turn the lettering around on the sectional when in track up mode?
Tom Clark
RV-6 Sold
F1 Rocket
Lake Norman Airpark - 14A
03-14-2013, 01:34 PM
UN-Thread Creep..
Any body have and ideas. Bob your answer kind of works, except I get traffic many miles from me routinely. Airliners or other high altitude stuff as well as low altitude, maybe a hundred miles away.
VAF #818
03-14-2013, 01:54 PM
I believe that they deliberately reduce the range in class-B to reduce the congestion on 1090Mhz.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
03-14-2013, 02:31 PM
That may be but I was just on the south side of the B, not more than 35 miles south and still had virtually no traffic inside the rings.
Keep answering..
VAF #818
03-14-2013, 02:46 PM
The ADS-B ground system is set up to only broadcast TIS-B and/or ADS-R tracks within a certain altitude and distance of aircraft that are transmitting ADS-B Out positions *and* are also capable of receiving ADS-B In.
So, you may be seeing traffic within that alt/distance of somebody else who's participating in the ADS-B system?
Dave
Dave Setser
RV-7 airworthy!
Nashua, NH (KASH)
Putting the "slow" in slow-build since 2004!
03-14-2013, 03:57 PM
Receiver and/or display issues...
Radomir
RV-7A sold
03-14-2013, 04:52 PM
The DFW area and the central part of the country will be the last areas of ADS-B to be turned on. The flight inspection commissioning for this area is not scheduled until late 2013 or early 2014. The Houston area is commissioned and is providing service in southern Texas.
However, we will be seeing some functions, sometimes intermittently, of the ADS-B in this area as the system is being installed and tested prior to the actual commissioning.
Dan Burdette
Skyview, ADS-B, Garmin 420W, TT Gemini AP
RV-9A, IO-320, E-Mag
Guthrie-Edmond Rgnl, OK (KGOK)
________
