A mild acid solution will remove blue discoloration from the pipes. If I recall, we used to use a mild acetal acid solution to remove most of the blue and some of the brown after welding stainless steel. Perhaps vinegar would be strong enough to do the same. Motorcycle shops sell compounds such as Dyno Kote and Blue Shield the help (slightly) in the reoccurrence.
It's worth a try I suppose. I'm going to let mine turn brown!
