Old 03-01-2013, 01:27 PM
Sig600 Sig600 is offline
Default My head hurts, someone please 'splain!
So I fiddled with the brakes and tires the other night, trying to get everything together. I know the answer is right in front of me, but I can NOT figure out how to get the calipers and wheel/tires on. If you put the calipers on you can't get the wheels on, if you put the wheels on you can't get to the back of the calipers to secure them.
I know it's got to be something stupid/simple, but I'm just not figuring it out.
Anyone? No one posts pictures of the process in any build logs, I assume because a monkey should be able to figure it out!
Next?, TBD
IAR-823, SOLD
RV-8, SOLD
RV-7, SOLD
Old 03-01-2013, 01:40 PM
John Clark's Avatar
John Clark John Clark is offline
Here is a discussion of the brakes. The short answer is that you mount the caliper assembly, then remove the two bolts holding the caliper together, where the lining is, and then mount the wheel. Then you can replace the "outer" pad and holder. Be sure to safety the bolts.
http://www.eaa.org/chapters/resource...me_a_brake.pdf
John Clark ATP, CFI
FAAST Team Representative
EAA Flight Advisor
RV8 N18U "Sunshine"
KSBA
Old 03-01-2013, 01:47 PM
Vern's Avatar
Vern Vern is offline
Default Resource
http://www.youtube.com/watch?v=sgym2VmQBF8
Best to watch someone the first time.
Schematics of parts available in Spruce Catalogs
Vern Darley
Awarded FAA "The Wright Brothers 'Master Pilot' Award"- for 50 years safe flying
RV-6A N680V / RV-10QB N353RV
Luscombe 8E N2423K 50+years
Hatz Biplane N2423Z soon to be birthed
Falcon RV Squadron Founder
KFFC Hanger D-30
Peachtree City, Ga
770 310-7169
EAA Technical Counselor #5142
EAA Flight Advisor #486336
ATP/CFI/A&P/DAR
Old 03-01-2013, 02:07 PM
RV7Ron's Avatar
RV7Ron RV7Ron is offline
Dont feel bad...I'd never seen one assembled or disassembled before and the drawings were very inadequate. I must've stared at that darn thing for an hour scratching my head. And I call myself a Mechanical Engineer! It was a good learning experience and I got a good chuckle out of it later...and I posted it on my blog to help others navigate this puzzle.
Ron Duren
Mechanical Engineer
"SportAir PhD"-RV Assembly/Composites/Electrical
Denver, CO (KBJC)
RV-7 'Tip Up'
Flying!! as of 3/16/14
IO-375/WW 200G-CS/SkyView/Dual P-mags
N531R "Wablosa" Wings of Red
http://www.ronsrv7project.blogspot.com
Old 03-01-2013, 02:22 PM
Rupester Rupester is offline
Yep ....exactly the same experience (and I too am a mechanical engineer.)
Terry Ruprecht
RV-9A Tip-up; IO-320 D2A
S. James cowl/plenum
(Dues paid thru Nov '18)
Old 03-01-2013, 02:27 PM
ccsmith51's Avatar
ccsmith51 ccsmith51 is offline
I'm an electrical engineer and had no problems at all with them.
Chris Smith
Maule M5-180C (Sold)
RV-6 O-360 CS (Sold)
RV-4 O-360 FP (Sold)
Full-time in the other type of RV....
Old 03-01-2013, 02:52 PM
flyboy1963's Avatar
Default important safety note! Video may mislead us?
Vern, if I'm not mistaken, it is a BAD idea to remove the axle nut before letting the air out of the tire!!! If the rim were seriously cracked, it could blow apart when the nut is removed. A local AME slapped me for doing this at my last annual!...and of course had a story about seeing it happen and someone being injured (perhaps with a larger wheel, but still!)
Perry Y.
RV-9a - SOLD!....
Lake Country, BC
Old 03-01-2013, 03:00 PM
pierre smith's Avatar
Default Negative.
Not so, Perry. I've always inflated ALL my tires, including my large Air Tractor tires before mounting them and have never deflated any tires, in 43 years, including my RV-10's before I remove them. The through-bolts hold the wheel together, not the axle nut.
Best,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 03-01-2013, 03:22 PM
I know! I've built several cars and do my own maint. This though has me stupefied.
Thanks to all the replies!
Next?, TBD
IAR-823, SOLD
RV-8, SOLD
RV-7, SOLD
Old 03-01-2013, 03:29 PM
kevinh's Avatar
kevinh kevinh is offline
Ok - that was really funny!
-kevinh, Track my RV-7A, flying, alas, sold in 2013 after 450ish hours. (I'm now building something different)
