Old 02-24-2013, 06:00 AM
Robert M's Avatar
Robert M Robert M is offline
Default Wiring in a light to fuel pump system
DISCLAIMER: I know very little about how electricity works.
I was wanting to put an indicator light in the circuit for my fuel pump to indicate operations. I've tried a few things but nothing works. I can get the pump to run but no light or the light comes on and no pump.
Here's a pic of the current wiring...
I didn't have it in the pic but there is a 5 amp fuse between battery and switch.
Any suggestions as to adding a light to the system?
"Pilots: Looking down on people since 1903"
(author unknown)
RV-9, N556RM, O-320, Dual PMags, Catto 3 blade.
FLYING since 2018
Mosquito XEL ready for flight
Old 02-24-2013, 06:16 AM
Brantel's Avatar
Brantel Brantel is offline
Just put em in parallel similar to this...
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 02-24-2013, 06:51 AM
Robert M's Avatar
REALLY, it's that easy? DANG!
(author unknown)
FLYING since 2018
Old 02-24-2013, 07:01 AM
AltonD's Avatar
AltonD AltonD is offline
For what its worth, I installed one. I still forget and leave the darn thing running. I have a blue light. I have had passengers ask "What does that mean?"
Alton DeWeese
N526RV RV7A Tip Up, IO360 180 W/Hartzel BA prop.
Flying ~950 hours since Aug 2010
N4IDH
Construction Log
?The secret of getting ahead is getting started. The secret of getting started is breaking your complex overwhelming tasks into small manageable tasks, and then starting on the first one.?
?Mark Twain
Old 02-24-2013, 07:21 AM
GrayHawk's Avatar
GrayHawk GrayHawk is offline
Aha! You should never use blue. The eye is not very sensitive to blue. The luminance value (brightness) comes from about 30% Red, 60% Green, 10% Blue. You should use red or green (or red+green = yellow) and then make it flashing and then put some words on it (legend) like "DANGER".
GrayHawk
My rebuild log: http://www.cherryfamily.net/bill/n63tx/rebuild/
Texas Hill Country Hangar For Sale: http://www.myspicewoodhangar.com/default.htm
Last edited by GrayHawk : 02-24-2013 at 10:13 AM. Reason: Edited as some people can't see the smiley face.
Old 02-24-2013, 07:57 AM
agirard7a's Avatar
agirard7a agirard7a is offline
Default Dummy light
I rigged up a white indicator light on my panel
For the fuel pump.
Very easy. Just hook it to the panel switch
to the fuel pump. When the pump is powered, the light
Is as well.
Steinair sells very nice little indicator lights.
various colors.
Al Girard, Newport, RI
N339AG
RV-9
Old 02-24-2013, 08:32 AM
DeltaTango's Avatar
DeltaTango DeltaTango is offline
In the airline world, a blue light is used to show "a temporary system in normal operation".
It's my opinion that different color lights are a good idea to allow the pilot to react to a situation based on color. If all warning lights are red then we learn to ignore a light because we expect to see a red light when the fuel pump is on. If the red light happens to be "low oil pressure" we might not notice until something bad happens.
I would keep the number of lights to a minimum. Use green or blue for things like fuel pumps, flaps. I would save red and yellow for things that are bad and will be bad soon items.
David
Old 02-24-2013, 09:10 AM
rvmills's Avatar
rvmills rvmills is offline
IMHO, placement of annunciator lights is important too. When I purchased my plane, the buddy that sold it to me and checked me out in it, would ask me "what the heck is that boost pump light still doing on". It was a little green LED placed way down in the lower right corner of the panel (RV-6), just above the air vent...almost worthless there!
When I did a panel upgrade, annunciator placement was an important element to me. I went with this:
I did use blue, because (as David said) blue in the jet at work means system or valve position or normal operation (including fuel crossfeed and spar valve position). I just used blue to indicate boost pump (it equates to fuel in my brain), and green to indicate landing light (like 3 green, green equates to landing gear or landing light in my pea-brain).
FWIW, I set my annunciator system methodology up as cool colored lights (green/blue) OK for TO and LNDG, hot colored lights (yellow/red) not OK for TO and LNDG. I think I heard Paul Dye describe it that way...probably stole it from him!
I don't disagree that blue or green are less attention getting, but also concur with not wanting to desensitize to red or yellow lights. Put them in front of your eyeballs, and all colors should work OK. And if you fly at night, the blue and green being a bit dimmer is not a bad thing during TO and LNDG either.
Sounds like the OP has the light rigged already, so none of this may matter to him, but those contemplating an annunciator panel might take nugget away.
Bob
Bob Mills
RV-6 "Rocket Six" N49VM
Reno-Stead, NV (KRTS)
Old 02-24-2013, 09:29 AM
AirbusPilot AirbusPilot is offline
Like me just install an Andair pump, it is so noise that you don't forget is on
Fernando Abasolo
Santiago Chile
SubSonex waiting for tailkit to arrive
Flying phase II RV-8 (SCSE) Serial Number 83290, Tail Number CC-AJC
Flying RV-8 (SCTB) Phase II 600 hours and counting since February 22nd 2010
Serial Number 82727, Tail Number CC-PXG
Lyc. IO-360, Hartzell Prop
VAF #2056
EAA Member 774981
Old 02-24-2013, 09:40 AM
L.Adamson's Avatar
L.Adamson L.Adamson is offline
My fuel pump switch lit red, and a amber light was included with the annunciator lights. I had a problem forgetting the fuel pump with Piper products.
